Local Time 16:51 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Log File Routines.
Phil23
Posted: 09:04pm 05 Nov 2019
Hi All,
Back looking at this from nearly 2 years back & wondering if I'm taking the right approach or whether I could do it better.
Basically it's been logging data on the SD card since 2017.
Logs every 15 minutes into the hour.
Still trying to get it all back in my head as to my logic at the time.
Any suggestions on an alternate approach.
(Iritating thing is the seconds stamp in the log varying....).
Phil.
  Quote    SetTick 2000, MainInt,1
SetTick 30000,ChkTime,2
If Touch(x) <> -1 Then CheckTouch
If DoLog=1 Then LogData
   UpdateLCD
Loop
Sub MainInt
 ReqComs
'UpdateLCD
 UpdateConsole
End Sub
Sub SendLog
xmodem Send "SpaLog.csv"
End Sub
Sub ChkTime
IF Val(Mid$(Time$,4,2)) Mod LogInt=0 And LogDone=0 Then
   DoLog=
1
Else If Val(Mid$(Time$,4,2)) Mod LogInt<>0 And Logdone=1 Then
   DoLog=
0:LogDone=0
End If
End Sub
Sub LogdataOld
If DoLog=1 And LogDone=0 Then
OPEN "TestLog.txt" FOR Append AS #2
Print #2, Date$;",";Time$;",";TmpScAmb;",";TmpScPan;",";TmpScCur;",";TmpScInp;",";TmpScOut;",";FlowRate;",";SlrVlt;",";FlowRate*(TmpScOut-TmpScInp)*70.2
Close #2
   LogDone=
1
End If
End Sub
Sub Logdata
IF Dir$("SpaLog.csv", File)="" Then
OPEN "SpaLog.csv" FOR Append AS #2
Print #2, "Date,Time,TmpScAmb.,TmpScPan,TmpScCur,TmpScInp,TmpScOut,FlowRate,SlrVlt,FlowRate"
Close #2
End If
IF Dir$("HeatLog.csv", File)="" Then
OPEN "HeatLog.csv" FOR Append AS #3
Print #3, "Date,Time,TmpChAmb,TmpChRof,TmpChLng,TmpChCel,TmpChBed,TmpChOf1,TmpChOf2"
Close #3
End If
Close #2
Print #3, Date$;",";Time$;",";TmpChAmb;",";TmpChRof;",";TmpChLng;",";TmpChCel;",";TmpChBed;",";TmpChOf1;",";TmpChOf2
Close #3
   LogDone=
1
End If
End Sub
Dim Float TmpChAmb,TmpChRof,TmpChLng,TmpChBed,,TmpChOf2,TmpChCel
Quazee137
Posted: 12:27pm 14 Dec 2019
This may fix it.
Sub ChkTime
 Ltime$=time$
   DoLog=1
   DoLog=0:LogDone=0
 End If
End Sub
then in subs
LogdataOld
Logdata
change time$ to Ltime$
