Local Time 16:28 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SETTICK and H7
Tinine
Posted: 08:09pm 05 Nov 2019
The H7 is many times faster than the MX170 BUT the minimum SETTICK is still 1ms. Any reason to not set off a 2KHz, 50% PWM and have it feed a input interrupt to get a 500usec rate?
Posted: 04:56pm 06 Nov 2019
  Quote  Any reason to not set off a 2KHz, 50% PWM and have it feed a input interrupt to get a 500usec rate?
That should work fine and very little extra overhead
