Local Time 16:28 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Using Bin2Str$ in function.
Greg Fordyce
Posted: 10:41pm 30 Oct 2019
Is it possible to use Bin2Str$ in a function? Sample code and console output showing syntax error. Cheers, Greg.
> list
 Option default integer
 Print Bin2Str$(uint16, 12345)
 a = crc("uint16", 12345)
Function crc(parm$, x)
Print parm$, x
 crc = x * 2
   Print Bin2Str$(parm$, x)
End Function
> run
90
uint16 12345
[10] Print Bin2Str$(parm$, x)
Error: Syntax
KeepIS
Posted: 01:07am 31 Oct 2019
The first call to Bin2Str$: Print Bin2Str$(uint16, 12345) uses the predefined value unit16 as the type qualifier.
The second call appears to use the string "uint16" as the type qualifier.
I haven't used the Bin2Str$ function before, I may be having a seniors moment with this post
Mike.
Posted: 05:05am 31 Oct 2019
I don't think the function evaluates the first paramater
Do something like this
  Quote    OPTION DEFAULT INTEGER
PRINT Bin2Str$(uint16, 12345)
 a = crc(
1, 12345)
FUNCTION crc(p, x)
 crc = x *
2
SELECT CASE p
CASE 1
PRINT Bin2Str$(uint16, x)
CASE 2
'etc
 END SELECT
END FUNCTION
You only need to code for the options you are likely to use.
Greg Fordyce
Posted: 09:50am 31 Oct 2019
Thanks Jim, I hadn't thought of using the case statement, that solution will work for me. Cheers, Greg
