Forum Index : Microcontroller and PC projects : Pic32prog Error code: -1
| Greg Fordyce Senior Member Joined: 16/09/2011 Location: United KingdomPosts: 153 |
I am trying to update an E100 Version 1D board using MMFlash. I keep getting the same error, not sure what I am doing wrong. The board has a pic16f1454. Programming slave device -d ascii:COM3 "D:\Downloads\Micromite_Firmware\Micromite_Plus_V5.05.02.hex" Programmer for Microchip PIC32 microcontrollers, Version 2.0.220 Copyright: (C) 2011-2015 Serge Vakulenko (ascii ICSP coded by Robert Rozee) Adapter: :::::::::::::::::::: Error code: -1 Programming completed in 10.532 seconds Greg |
bigmik![]() Guru Joined: 20/06/2011 Location: AustraliaPosts: 2981 |
Hi Greg, Have you put the pic16 into PROGRAM mode? (Momentarily short the 2 pin header and the led should light) Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Cheers Mick, That's done it, the E100 has a button marked select just for this! Greg |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10043 |
![]() Smoke makes things work. When the smoke gets out, it stops! |
GDay Greg, Great news.. Glad I am not totally useless.\\ Kind Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
