Local Time 16:20 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : chdir "" resets mm.errno
crez
Posted: 02:46am 10 Oct 2019
I thought that most commands did not effect mm.errno unless an error occurs. I was expecting it to hold the code for the last error that occurred. I was surprised to find that mm.errno was being reset to 0 in my program and narrowed it down to the chdir "\" command, even though this command did not itself cause an error. I am using the Armmite F4 firmware, but have nothing else to test it on at the moment. Has anyone else found this?
Cyber
Posted: 05:20am 10 Oct 2019
This behaviour looks ok to me.
mm.errno now contains error code for chdir "\" command, which is 0, meaning command completed successfuly.
It is common sense in other programming languages.
crez
Posted: 11:38am 10 Oct 2019
So it looks like I need to check for errors after each file operation. I was working on the standard micromite system where "They are reset to zero and an empty string by RUN, ON ERROR IGNORE or ON ERROR SKIP". I was relying on the info in mm.errno persisting until one of the above three commands occur. I wanted to hold off on acting on the error until a certain spot in the program where I could shut down in an orderly way. Thanks for your reply.
