Local Time 16:20 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Use of pins
foxleyboy
Posted: 02:45pm 30 Sep 2019
Hi.
I keep getting the message 'Pin xx is reserved on startup' !
So are these pins un usable? If not, then how do I use them.
Also Pins 4 and 5 are used for the PGED and PGEC lines on V2 so are these still usable or does the 'bridge chip' go to high impedance when you run a program?
Many thanks
Roy
Posted: 03:46pm 30 Sep 2019
  foxleyboy said  I keep getting the message 'Pin xx is reserved on startup' !
Which device?
Which pins?
Which mmbasic version?
Welcome to the forum--but when you post, provide information to help us to help you.
Edited 2019-10-01 01:47 by lizby
Posted: 04:16pm 30 Sep 2019
  foxleyboy said  Hi.
generally they are only "reserved" when programming (flashing) the firmware. You can use them in your own code
foxleyboy
Posted: 04:48pm 30 Sep 2019
I am useing the LCD backpack V2.
Prog software is V 3.8.1 OS Ver:10
Pins that so far give the  'Pin xx is reserved on startup' message are Pins 25 and 14. There may be others.
foxleyboy
Posted: 04:49pm 30 Sep 2019
Maybe I should also say the this Prog software is MMEDIT
Posted: 05:15pm 30 Sep 2019
  Quote  'Pin xx is reserved on startup' message are Pins 25 and 14
These are the SPI pins used to drive the display. If you are not using the display type OPTION LCDPANEL DISABLE and they will be returned to normal usage. DON'T DO THIS IF YOU DON'T UNDERSTAND HOW TO RE-CONFIGURE THE DISPLAY FOR FUTURE USE>
