Local Time 11:29 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite Plus: DIR$(fspec) bug with long fspec file name
erbp
Posted: 10:44am 24 Sep 2019
I guess this one will be for Geoff.
Using MMBasic 5.05.02 Beta 1 on a MM+ (E100) I have found that the DIR$(fspec) function incorrectly reports that a file does NOT exist when it's name is entered as the fspec parameter and the file name is longer than 31 characters. The same applies if using wildcards in the fspec parameter too - see below.
Micromite Plus MMBasic Ver 5.05.02 Beta 1
Copyright 2011-2018 Geoff Graham
> CHDIR "LOGS"
> FILES
A:/LOGS
      743  Test12345678901234567890123.log
      743  Test123456789012345678901234.log
0 directories, 2 files
> DIM FN$
> FN$ = DIR$("Test12345678901234567890123.log",file): ? FN$    <ok with fspec at 31 chars
> FN$ = DIR$("Test123456789012345678901234.log",file): ? FN$   <no match if fspec > 31 chars
> FN$ = DIR$("Test12345678901234567890123*.log",file): ? FN$
> FN$ = DIR$("Test123456789012345678901234.lo*",file): ? FN$
> FN$ = DIR$("Test123456789012345678901234.*",file): ? FN$     <ok, when fspec shorter again
Phil
Posted: 11:08am 24 Sep 2019
The maximum filename length for pattern matching is 31 characters - just a question of memory usage
erbp
Posted: 11:13am 24 Sep 2019
Hi Peter,
Thanks do you know if that is specified in any of the manuals? I looked before I posted but couldn't find anything that appeared relevant. Did I miss it?
Phil.
Posted: 09:21am 25 Sep 2019
No, it is not mentioned anywhere... one of those things that slipped past.  I will remove this limitation in the next version.
erbp
Posted: 09:59am 25 Sep 2019
Hi Geoff,
Thanks - I understand if there does need to be some limitation on the pattern matching that can be applied, but if there is then it should throw an error if that limit is exceeded - not just return an incorrect answer which the calling code will interpret as being fact.
Cheers,
Phil.
