Local Time 11:29 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : find and replace window disappearing on MMEDIT
jeffj
Posted: 07:23am 15 Sep 2019
The little window that normally appears on the screen when "find/replace " is pressed
flashes and then disappears but is in the corner when MMEDIT is minimised, clicking on it makes no difference.
I am using win 10
I don't think this is am MMEdIT problem as I have reloaded the software and switched the computer on and off.
It works ok on notepad and word programmes
Any help would be appreciated
Jeff
jeffj
Posted: 03:04am 17 Sep 2019
Plse cancel my post It fixed itself jeff
Posted: 04:37am 17 Sep 2019
My apologies for not responding to the initial post.
In cases like that, I usually recommend deleting the data folder contents while re-installing.
That refreshes things like window position which can cause problems if they get corrupted.
Glad it's working again for you.
