Local Time 16:00 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Armmite H7: 5.05.09, MOD file playback
Posted: 04:01pm 04 Sep 2019
Minor update that includes playback of .MOD files like the Colour Maximite.
Armmite1.3.zip
Armmite H7 Manual.pdf
MOD files play on a continuous loop with the command
PLAY MODFILE fname$
Playback is stopped with
PLAY STOP
Volume can be controlled with (0-100)
PLAY VOLUME left%, right%
The playback can be paused with
PLAY PAUSE
and resumed with
PLAY RESUME
The attached zip file includes a sample modfile. Playback is in 12-bit stereo at 44100 Hz
Edited 2019-09-05 02:36 by matherp
PicFan
Posted: 08:39am 06 Sep 2019
Hi Peter !
Thank you for your commitment. It should be possible to build an SDR radio with the H7. What is your opinion ?
Greetings from Tyrol!
Wolfgang
Posted: 09:20am 15 Sep 2019
Trivial fix for bug with 4.3" SSD1963 in 16 bit portrait mode
Armmite1.3.zip
This also includes an experimental capability for games programmers. You can now play a WAV file at the same time as playing a MOD file.
The syntax is:
PLAY EFFECT wavfilename$ [,interrupt]
The WAV file must be stereo and recorded at 44100Hz otherwise you will get an error. The optional interrupt is triggered when the wav file completes. The MOD file continues playing continuously.
  Quote   It should be possible to build an SDR radio with the H7
Sorry - know nothing about SDR radio so can't comment.
