Local Time 15:38 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Touch cannot be calibrated  with loadable driver MM+  v5.5.02
disco4now
Posted: 01:04pm 14 Aug 2019
I have a loadable driver for an ILI9341_P16 from sometime ago, was working on 5.1 last time I used it.
I upgraded to 5.0502 beta6 and reloaded the driver.
The screen works OK to display.
The OPTION TOUCH 51, 33 is accepted,
but when GUI CALIBRATE is tried it returns
Display not configured, so can't be calibrated, and GUI INTERRUPT also returns
Display not configured.
I figured it must be looking for a display type , which the loadable driver is not setting.
I entered OPTION LCDPANEL USER, 320, 240 and it then allowed
GUI CALIBRATE
(Its actually a CSUB driver)
and error about MM.DRAWRECTANGLE not found (something like that) was returned initially but the touch is now working with the loadable driver
Does a loadable driver now need to set a display type or something in the initalisation that was not previously required?
> option list
OPTION LCDPANEL USER 0, 0
OPTION TOUCH 51, 33
GUI CALIBRATE 0, 3786, 3745, -916, -681
Gerry
Edited 2019-08-14 23:07 by disco4now
F4 H7FotSF4xGT
Posted: 01:44pm 14 Aug 2019
  Quote  Does a loadable driver now need to set a display type or something in the initalisation that was not previously required?
Yes
I've updated some of my drivers but I'm sure I will get reports of this
Just include:
   Option->DISPLAY_TYPE=20;
somewhere in the driver initialisation
Edited 2019-08-15 00:43 by matherp
