Local Time 15:38 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic and keyboard layout
Decoy
Posted: 06:01pm 09 Aug 2019
Hi guys
I just my UBW32 MaxiMite up and running with a PS/2 keyboard. I haven't been
this excited in years :)
However, my PS/2 keyboard has " on what corresponds to Æ (Danish letter), and other
such problems. Is there any way to choose keyboard layout in MMBasic? I should I
attempt to get an american-style layout?
Thanks,
ceptimus
Posted: 06:10pm 09 Aug 2019
You can use the CONFIG KEYBOARD command to set the keyboard type - so
CONFIG KEYBOARD BE
will select a Belgian keyboard layout.
I'm sorry, there isn't a Danish specific version though - the options are US UK FR GR BE IT ES for USA, UK, French, German, Belgian, Italian, Spanish keyboard layouts. I suppose German might be closest to Danish?
Once you've set it, it's preserved during power-down, so you should only need to do it once.
I don't think the built-in fonts support characters like Æ though, but at least you should be able to get most of the keys in the right place. You can also define your own fonts with special characters if need be.
Edited 2019-08-10 04:16 by ceptimus
Decoy
Posted: 06:27pm 09 Aug 2019
Thanks, that sounds great. I will go try that right away. It is not because I need
to use æ, ø and å - my problem is the placement of the symbols. It would be
impossible to learn a new layout :)
I'll report back in half an hour!
Decoy
Posted: 07:00pm 09 Aug 2019
Worked like a charm, thanks!
Poppy
Posted: 07:48pm 09 Aug 2019
  Decoy said  Worked like a charm, thanks!
Does it? Can you type "æ, ø and å" directly now?
The "German" setting for example does not support "umlauts" (mutated vowels = Ää Öö Üü) it just sets the keyboard to matching "QWERTZUI" instead of general "QWERTY".
P.S.:
Try:
FOR A = 1 to 255
PRINT CHR$(A)
NEXT A
There aren´t many special characters among.
I just checked up "PC BASIC" (GW BASIC Emu) for comparison and there they are.
https://sourceforge.net/projects/pcbasic/
Edited 2019-08-10 06:02 by Poppy
Andre ... such a GURU?
Decoy
Posted: 06:52am 10 Aug 2019
Poppy, I don't need the æ, ø and å on the MaxiMite. I need symbols like " and = to
be in the same places as I am used to. I am almost there. German layout apparently
uses QWERTZ instead of QWERTY, I can never adjust to that :)
Right now I am using italian - this is the closest, but still has problems. I wish
there was a Danish layout.
Decoy
