Local Time 15:32 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Checking to see if a wav file is playing
karjo238
Posted: 04:58am 29 Jul 2019
Alright, I've got a silly question, and after a bit of searching, I can't seem to find an answer. I want to play a wav file, wait for it to finish, then play another wav file. The second wav file can be different from run to run, so I can't just make it one file.
Is there a variable that can be checked in MMBasic to see if the wav file is playing? There was one called audio_is_playing, but that doesn't seem to work for WAV files.
As always, any help is gratefully appreciated!
Joseph.
KeepIS
Posted: 05:13am 29 Jul 2019
Not knowing the platform etc but from the Plus manual.
There is an optional interrupt setting:
PLAY WAV file$ [,interrupt]
The interrupt is called when the file is finished playing.
karjo238
Posted: 11:46pm 29 Jul 2019
Sorry, I didn't make myself too clear the first time around. I'm using MMBasic 5.04 on a Micromite Extreme 144, and what I really wanted to find out was whether there was a system variable to flag audio (of any kind) playing.
the [,interrupt] option doesn't quite work for what I need, so I was looking (maybe in vain) for another option.
Many thanks,
Joseph.
KeepIS
Posted: 02:36am 30 Jul 2019
Sounds like a special situation, my interrupt simply sets a flag, there are a number of places in my Grandfather clock that play different sound files, they all check the playing flag before starting and set it once they start.
I haven't seen any other way mentioned, but Geoff or Peter could answer that definitely.
Mike.
karjo238
Posted: 07:48am 30 Jul 2019
  KeepIS said  Sounds like a special situation, my interrupt simply sets a flag, there are a number of places in my Grandfather clock that play different sound files, they all check the playing flag before starting and set it once they start.
Mike.
Aargh! I wasn't in the right headspace, and you're absolutely right! I made my own flag, and all is well!
Many thanks for giving me a gentle nudge in the obvious direction
Joseph.
KeepIS
Posted: 09:01am 30 Jul 2019
Been there done that (all the time lately), that's what's great about these forums, someone usually comes up with something that gives you a nudge towards that OH feeling
Mike.
