Forum Index : Microcontroller and PC projects : Limits of variable names
| Page 1 of 2 |
| karjo238 Regular Member Joined: 12/10/2018 Location: New ZealandPosts: 60 |
Hey there! I've recently purchased a Micromite Extreme 144 to give all my MMBasic projects a bit more pep, but I'm running up against problems with variable names, and can't find a clear answer in the manual. I am running MMBasic version 5.0502, and am trying to run a program with variable names of X and X1, J and J2 and so on. These worked on my old Colour Maximite, but now don't seem to be any more. So, what I need to ask is: What are the rules for creating variables in this version of MMBasic? Can you only have a total of 26 variables, i.e. one per letter, or can you have more and I'm just programming it wrong? Any help that can be provided would be most appreciated. Cheers, Joseph. |
| seco61 Senior Member Joined: 15/06/2011 Location: AustraliaPosts: 205 |
Hi Joseph. As per the Micromite manual, variables can be up to 32 characters in length: Regards Gerard (vk3cg/vk3grs) |
| disco4now Guru Joined: 18/12/2014 Location: AustraliaPosts: 1162 |
Not sure where I copied it from but see below. Your X,X1,J and J2 should be OK, but you can use variable names up to 32 characters. As many as you need until you run out of memory for them. Type the MEMORY command to see how much you have used. I think what may be different in Micromite is you can't use j$,j%,j together once j is used for a string or integer it cant be used again, so if you have X$,X1$ etc as well then you would have a problem. Maximum length of a variable name or a label is 32 characters. Maximum number of dimensions to an array is 8. Regards Gerry F4 H7FotSF4xGT |
| CaptainBoing Guru Joined: 07/09/2016 Location: United KingdomPosts: 2171 |
Morning Joseph. Doesn't sound like you are doing anything wrong and single character/26 variables is definitely not the case. can you post a bit of your code for us to see? h |
I probably need to clarify what's happening here. This line: X1=C(C1,1)+(C(C1+1,1)-C(C1,1))*(C1-Int(C1)):X=S1:Y=S2 Throws an error "X already declared". X has been declared earlier in the program, and X1 is the new declaration. They are both integers, so *in theory* they should both work. I think. Can anyone shed a light on this? |
The problem is I can't really. All I did in the first case was take this code: http://vintage-basic.net/bcg/superstartrek.bas and make a few modifications to make it work on MMBasic 4.5. Now that there is more specific type-checking, I'm going to have to go down the route of rewriting the code from scratch, which won't be too much of a drama as I have already done a version in Python 3 which has SUBs, FUNCTIONs, etc, and all I really need to do is change the program structures from Python to BASIC. Many thanks for your guidance anyhow, Joseph. |
| Turbo46 Guru Joined: 24/12/2017 Location: AustraliaPosts: 1694 |
Hi karjo238, Line 440 of the original program says: 440 P=10:P0=P:S9=200:S=0:B9=2:K9=0:X$="":X0$=" IS " So X is already declared as X$. As disco4now said if you use X$ you cannot use X%. Using X without declaring the type of variable will default to a floating point anyway (X!). All you need to do is change all occurrences of X$ to XA$ (for example) and do the same for other variable names that cause the same problem. You may want to change all X variables to X% and similar to make them integers rather than floating point variables (after you have the program working). The program should then run faster. Bill Keep safe. Live long and prosper. |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1785 |
The program should then run faster. Bill Yes, it should. But it does not! A short test on a ARMmite MMBasic Version 5.04.33: Dim i,a As integer Dim j,b As float Timer=0 For i = 1 To 50000:a = i + i:Next i For i = 1 To 50000:a = i * i:Next i Print Timer Timer=0 For j = 1 To 50000:b = j + j:Next j For j = 1 To 50000:b = j * j:Next j Print Timer End Result: 854 On a MM2 the same relation - float is faster than integer -, but slower. In general, I do not think it's a good idea to use integers to get faster. Maybe Geoff has an idea why ...? Michael |
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3888 |
The program should then run faster. Bill Yes, it should. But it does not! A short test on a ARMmite MMBasic Version 5.04.33: Hmmm ... Interesting indeed. Integers are a third slower than floats with MMBasic DOS: 62 & 47 PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Thanks Michael and Lizby, That's what happens when you assume. I am surprised and disappointed. Integers was one reason that I was waiting for MMBasic for the Maximite! Can somebody please explain? Bill Keep safe. Live long and prosper. |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12186 |
It does if you get your test code correct Dim i,a As integer sets i as a float and a as an integer try dim integer i,a or Dim i as integer,a As integer or OPTION DEFAULT INTEGER DIM i,a DIM FLOAT j,b etc. |
Thank you Peter, So each time around in the loop the integer is converted to a float to add the two numbers. That's what causes the longer time for the 'integer' part of the test to execute. Timings on my DOS MMBasic with the corrected program.were: 78 94 My faith is restored. Bill Keep safe. Live long and prosper. |
oops! SORRY! Thanks Peter! New results for Dim integer i,a Dim float j,b ... and the code above 854 But the difference seems very small. Dim integer i,a Dim float j,b Timer=0 For i = 1 To 50000:a = i - i:Next i For i = 1 To 50000:a = i / i:Next i Print "Integer ="Timer"ms" Timer=0 For j = 1 To 50000:b = j - j:Next j For j = 1 To 50000:b = j / j:Next j Print "Float ="Timer"ms" End gives [code]Integer = 884ms Float = 855ms[/code] |
I think it's time to see at the details: Dim integer i,a Dim float j,b Timer=0 For i = 1 To 50000:a = i + i:Next i Print "+ Integer ="Timer"ms" Timer=0 For i = 1 To 50000:a = i * i:Next i Print "* Integer ="Timer"ms" Timer=0 For i = 1 To 50000:a = i - i:Next i Print "- Integer ="Timer"ms" Timer=0 For i = 1 To 50000:a = i / i:Next i Print "/ Integer ="Timer"ms" Timer=0 For j = 1 To 50000:b = j + j:Next j Print "+ Float ="Timer"ms" Timer=0 For j = 1 To 50000:b = j * j:Next j Print "* Float ="Timer"ms" Timer=0 For j = 1 To 50000:b = j - j:Next j Print "- Float ="Timer"ms" Timer=0 For j = 1 To 50000:b = j / j:Next j Print "/ Float ="Timer"ms" End Result: + Integer = 418ms * Integer = 411ms - Integer = 416ms / Integer = 468ms + Float = 429ms * Float = 426ms - Float = 424ms / Float = 431ms |
That is because most of the time is taken in parsing the commands. Just the reality of a Basic Interpreter I'm afraid. Note the comparatively slow integer divide. This is because the FPU supports double floating division but there is no H/W support for 64-bit integer divide |
But there is something else weird: If I exchange positions of the Dim's Dim integer i,a toDim float j,b Dim float j,b then the integers are slower than floats again:Dim integer i,a + Integer = 429ms * Integer = 422ms - Integer = 426ms / Integer = 480ms + Float = 418ms * Float = 416ms - Float = 414ms / Float = 420ms |
Yes, but this is again due to parsing. The integer variables are now after the float ones in the variable table so the parser takes longer to find them. The variable table is just a sequential list in the order created and the parser searches from the top until it finds a match to the variable name. To accurately see the difference between float and integers you need to do it both ways and average the results. |
Okay! Dim integer i,a Result:Dim float j,b Timer=0 For i = 1 To 50000:a = i + i:Next i For i = 1 To 50000:a = i * i:Next i For i = 1 To 50000:a = i - i:Next i For i = 1 To 50000:a = i / i:Next i Print "Integer ="Timer"ms" Timer=0 For j = 1 To 50000:b = j + j:Next j For j = 1 To 50000:b = j * j:Next j For j = 1 To 50000:b = j - j:Next j For j = 1 To 50000:b = j / j:Next j Print "Float ="Timer"ms" End Integer = 1712ms Float = 1709ms vs Integer = 1756ms Float = 1664ms ie sum for integers = 1712+1756=3465ms sum for floats = 1709+1664=3372ms On an ArmMite H7! |
Remove the divide and you will see integer slightly faster. Floating point divide is supported by hardware. 64 bit integer divide isn't. However, speed isn't really the issue. The key point is that integer arithmetic is exact whereas, even with double precision you will see rounding errors with FP Dim float i,a For i=1 To 10000*7 a=a+1/7 Next i Print Str$(a,5,15) End =9999.999999991743607 |
Hi Peter! I totally agree! I was just trying to say - and prove - something against the myth that (MMBasic) integers are in any case significant faster. I think that is important for us users. |
| Page 1 of 2 |
