Local Time 15:18 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : eXtreme backpack 144 LCD problem
nutson
Posted: 03:08pm 01 Jul 2019
I own an eXtreme backpack144 V1.1 with a 7" LCD mounted, supplied by WhiteWizzard. A few weeks ago I switched to VGA output (and did not note down the option list). VGA output works fine, but now I want to get back to the LCD again, but none of the OPTION LCDPANEL SSD1963xxxxx commands I tried brings the LCD back to life, the unit sticks to VGA output, LCD blank. My current OPTION list is CPU 252 /COLOURCODE ON /DISPLAY 24, 53 / LCDPANEL VGA / KEYBOARD UK /SDCARD 93,94 / LCDPANEL CONSOLE /RTC 15, 16 / HEARTBEAT ON. The unit is running MMBASIC 5.03.15
What commands do I need to issue to get the LCD going again? And, can I use both VGA and LCD and how? If part of the answer is "update to newer MMBASIC version " please point me to instructions howto (there is a PIC on the board, and a "mode" switch) I found an LCDPANEL RESET command in a manual but that seems not supported by this MMBASIC version
Nico Hattink
Posted: 03:32pm 01 Jul 2019
First you need to disable VGA
OPTION LCDPANEL DISABLE
The set up the TFT
OPTION LCDPANEL SSD1963_7_16,L,,142
Finally if you want to use the TFT as a console
OPTION LCDPANEL CONSOLE
  Quote  can I use both VGA and LCD and how?
No, it is either/or
To update the firmware see the instructions on the microbridge on geoffg.net. Your PCB has a built-in Microbridge
Lastest firmware version here Edited by matherp 2019-07-03
nutson
Posted: 04:34pm 01 Jul 2019
LCD is working again, thanks. Makes sense, the order of commands. I was probably scared losing all output. Keep up the good work on the mites I like the steady flow of innovation in software and hardware in this forum.
Nico Hattink
