Local Time 15:10 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Passed parameter when using Chat.
Tinine
Posted: 06:26am 19 Jun 2019
I have a procedure loaded on my E100:
SUB GetPos (addr)
Blah, blah, blah
END SUB
I run the procedure from MMEdit's terminal Chat and the first time;
GetPos 1
it works as expected but the second time, I get the error:
"ADDR" already defined
I am almost sure that I wasn't getting this error a couple of days ago(???)....Am I missing something?
goc30
Posted: 08:52am 19 Jun 2019
Hi tinine
can you clarify the context
version of Micromite
did you set the parameter before the call like this exemple
dim var1 as integer
do
call sprog1(var1)
loop
sub sprog1(adr as integer)
bla bla bla
end sub
Tinine
Posted: 11:15am 19 Jun 2019
Yes, I did all that...
I had a space between the procedure name and the parentheses. I removed the space and now all is fine...was that a no-no?
goc30
Posted: 12:31pm 19 Jun 2019
I have seen this space but I think that is was an keyboard error on copy of code in your post
