Local Time 15:10 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : resetting micromite
viscomjim
Posted: 12:25pm 12 Jun 2019
Is there any way to reset the uMite (28pin) with a command in a program other that to use the watchdog timer, for example if Xx = 30 the RESET. This would restart the uMite and run the program again via option autorun on.
Thanks for any ideas...
Posted: 12:26pm 12 Jun 2019
CPU RESTART
viscomjim
Posted: 01:13pm 12 Jun 2019
Thank you kind sir!!!
viscomjim
Posted: 03:30pm 12 Jun 2019
Can using cpu restart be in any way detrimental to the micromite?
Posted: 09:41pm 12 Jun 2019
  Quote  Can using cpu restart be in any way detrimental to the micromite?
No, it just executes a jump command to the start of the normal power-on initialisation sequence.
