Local Time 15:02 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Unexpected Text
palcal
Posted: 12:51am 27 May 2019
I am trying to make a small change to some code and have this error
[34] Else Rain = Cint(Rain)
Error: Unexpected text: Rain Æ ‡Rain)
I was using GFX term so I tried MMEdit with the same result
does anyone know what is causing this?
edit...I even tried using a different computer to do the edit and got the same error.Edited by palcal 2019-05-28
seco61
Posted: 02:28am 27 May 2019
Hi.
Without seeing the rest of the code, it would appear that it does not like the text after the ELSE command. The text displayed in the message looks like the "tokenised" version of "Rain = Cint(Rain)".
Have you got the formatting for the IF THEN ELSE correct? (Hard to tell without a bit more code visible - or what the before and after code looks like )
Gerard (vk3cg/vk3grs)
palcal
Posted: 03:02am 27 May 2019
What I am trying to do is, if the rain value is less that 10 print to 1 decimal place else no decimal place.
A larger snippet of code
If Rain < 10 Then
Rain = Cint(Rain*10)/10
EndIf
R$=Str$(rain,3)
This fails with the error, the coding is also wrongly formatted Str$(Rain,3) would
not give the decimal place
So I changed the way I did things to this
If Rain <10 Then
R$ = Str$(Rain,1,1)
Else R$ = Str$(Rain,3)
EndIf
This also fails with this error
[34] Else R$ = Str$(rain,3)
Error: Unexpected text: R$ Æ ¤rain,3)
palcal
Posted: 03:11am 27 May 2019
OK I have it working
I changed the code so that ELSE is on a separate line.
I thought it was OK to have
all on one line.
I now have
Else
R$ = Str$(Rain,3)
and it works OK
PeterB
Posted: 03:19am 27 May 2019
G'Day palcal
It's nice to see someone else tripping over the IF THEN ELSE MAYBE thing.
I have been using BASIC in various forms for many years and I still get it wrong. I think the rules keep changing.
Peter
Posted: 03:32am 27 May 2019
Yes, the ELSE needs to be on a line of its own. I'm a little late to this thread, so you have it sorted now, but the interpreter does not seem to really like having commands after the ELSE keyword. I also had this problem, but ever since I have put the ELSE on its own line, I have never had that problem again.
palcal
Posted: 03:50am 27 May 2019
Thanks to all.
seco61
Posted: 04:11am 27 May 2019
If you want to have the code on the same line as the IF THEN ELSE, the following format will also work (note: there is no ENDIF).
If Rain < 10 Then R$ = Str$(Rain,1,1) Else R$ = Str$(Rain,3)
Posted: 04:31am 27 May 2019
You could also do a single line by using a :
Else : R$ = Str$(Rain,3)
That is a method I often use when I have a lot of elseif's and simple code following.
palcal
Posted: 05:56am 27 May 2019
OK thanks.
Posted: 11:32am 27 May 2019
  palcal said   I am trying to make a small change to some code and have this error
There is
ELSEIF
or
ELSE IF
PeterB
Posted: 12:19am 28 May 2019
Good morning
Since we are admitting confusion about IF etc, something like this had me wacked a few weeks ago. I eventually gave up with the excuse that it was too slow for what I wanted but it still bugs me.
A = 2
B = 22
If A = B Then GoTo X
Else
Print "NOT EQUAL"
End If
GoTo OUT
X: Print "EQUAL"
OUT:
It does not print NOT EQUAL
If I change B to 2 it prints EQUAL
I know, "WHEN ALL ELSE FAILS, TRY READING THE INSTRUCTIONS"
BUT I DID.
Peter
Turbo46
Posted: 01:51am 28 May 2019
Hi Peter,
The manual says about your IF statement: 'This type of IF statement is all on one line'
I would have expected then that the ELSE statement would have thrown an error? I'll Try it out later when I can.
Turbo46
Posted: 03:32am 28 May 2019
I ran the program and got the same result as you. The lines following the IF statement are not being executed when the IF condition is not true.
The manual also says:
  Quote  The ‘THEN statement’ construct can be also replaced with:
GOTO linenumber | label’.
So I expect that it should be either: THEN or GOTO and having both might confuse the interpreter so I removed the THEN from the statement:
  Quote  If A = B GoTo X
and got the same result. It does not seem to be working as I expected. This may be a question for Geoff.
This version works as expected:
  Quote  A = 2
B =
22
IF A = B THEN
PRINT "EQUAL"
ELSE
PRINT "NOT EQUAL"
END IF
OUT:
seco61
Posted: 04:03am 28 May 2019
Hi.
If the IF command has an expression following the THEN then it is considered to be an IF statement with all parts on the same line.
As you have a GOTO following the THEN (or just a GOTO without the THEN), this is considered a one line IF statement. The ELSE on the following line will tried to be matched to a preceding IF - but as it cannot find a match it just ignores the statements from the ELSE to the ENDIF.
Some options for writing the statement:
A = 2
B = 22
If A = B Then GoTo X Else Print "NOT EQUAL"
GoTo OUT
X: Print "EQUAL"
OUT:
A = 2
B = 22
If A = B Then
GoTo X
Else
Print "NOT EQUAL"
Endif
GoTo OUT
X: Print "EQUAL"
OUT:
Edited by seco61 2019-05-29
Turbo46
Posted: 04:14am 28 May 2019
Hi seco61,
Yes, as above, the IF statement is considered as a single line statement but as you say the ELSE on the following line will be tried to be matched to a preceding IF.
As there isn't one, wouldn't you expect it to throw an error rather that ignore the following lines?
I would still expect:
IF A = B GOTO X
to work.
PeterB
Posted: 04:27am 28 May 2019
G'Day seco61 & Bill
Your second example looks a lot like mine except GOTO has been moved down.
The manual says the THEN statement can be replaced by GOTO????
My code is only meant to display the problem. The actual code was full of IFs etc.
But it does seem to have demonstrated some confusion about this area.
Peter
seco61
Posted: 04:46am 28 May 2019
Hi Peter and Bill.
My understanding is that "IF expr GOTO label" is also considered a one line IF statement, hence the same behaviour.
As regards reporting an error, it is a LONG time since I actually looked at the interpreter code, but I know being able to report this as an error could be quite difficult when you consider the sequential nature of the interpreter and the ability for code to be GOTO'd etc...
PeterB
Posted: 04:55am 28 May 2019
To me it reads as a multiline IF statement. The only complication is the GOTO but since it is not working, my interpretation is a bit sus.
Thank heavens for Cab. Sav.
Peter
PeterB
Posted: 12:21am 29 May 2019
Good morning sec061 & Bill
I bet you thought I had gone away
Your second bit runs but when equal it runs once and when not equal runs continuously.
Why am I not surprised?
I got out my David I Schneider Handbook of BASIC 1988. It only confuses me.
I am plucking up the courage to insert a GOSUB / RETURN just for fun.
Peter
