Local Time 14:54 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem with GUI Displaybox?
KeepIS
Posted: 09:27am 10 May 2019
ARMmite MMBasic Version 5.05.03 (H7)
Is the a limit to the number of lines in a Displaybox?
After 7, part of 8 is shown, 9 is missing, then ABCD displays.
If more lines are added the lines write past the bottom of the box, but the top remains where it is, so auto centering stops.
Could someone possibility check this for me?
[code]
const A_DBox = 5
dim InfoStr as string
FONT 4
GUI DisplayBox A_DBox,MM.hres/2,MM.Vres/30,MM.HRes/2.2,MM.Vres/1.05,RGB(WHITE),RGB(BLUE)
Infostr="1~2~3~4~5~6~7~8~9~A~B~C~D~E"
CtrlVal(A_DBox) = InfoStr[/code]
Posted: 09:27pm 10 May 2019
There is a limit of 10 lines in the standard code and I assume that Peter retained this in the ARMmite port. This is something that should be documented. I will check the manuals to make sure it is.
KeepIS
Posted: 09:59pm 10 May 2019
Thanks Geoff.
Mike
