Local Time 14:54 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Weird Corruption!
PhilTilson
Posted: 09:36pm 02 May 2019
I would welcome some help with this, please.
Here are a few lines from a fairly large MMbasic program - around 1300 lines:
sub GetLog(tStart$,tEnd$,fname$) '[013]
'This routine gets a start and finish time in string format
'then opens the fname$ file and prints the relevant log entries
LOCAL genin$,st%,end%,cur%
IF fname$="" THEN fname$="syslog.txt"
st%=(VAL(LEFT$(tStart$,2))*3600)+VAL(MID$(tStart$,4,2))*60)+VAL(RIGHT$(tStart$,2))
end%=(VAL(LEFT$(tEnd$,2))*3600)+(VAL(MID$(tEnd$,4,2))*60)+VAL(RIGHT$(tEnd$,2))
OPEN fname$ FOR INPUT AS #9
DO WHILE NOT EOF(9)
LINE INPUT #9,genin$
cur%=(VAL(MID$(genin$,10,2))*3600)+(VAL(MID$(genin$,13,2))*60)+VAL(MID$(genin$,16,2))
IF cur%>=st% THEN
PRINT genin$
ELSE IF cur%>end% THEN
EXIT DO
END IF
LOOP
CLOSE#9
END SUB
It's a simple routine to selectively read log entries.
The problem is that when I load it and try to run it, I get the following error:
[1297] End%=(Val(Left$(tEnd$,2))*3600)+(Val(Mid$(tEnd$,4,2))*60)+Val(Right$(tEnd$,2))
Error: Unexpected text: %Ç(©“tEnd$,2))·3600)»(©–tEnd$,4,2))·60)»©œtEnd$,2))
What the heck is all that about? When I go to edit the line, it prints exactly as it is in the source code. Any ideas?
Phil
Posted: 10:56pm 02 May 2019
I would try using a different variable name instead of END%
The strange characters are the tokens for the keywords which is why the error message looks odd.
Posted: 11:24pm 02 May 2019
Agreed. That would be the first thing I would try.
Avoid using any keywords as variable names, as that could confuse the interpreter.
This includes all command names, and all function names. None of them should be used for variable, array or constant names.
PhilTilson
Posted: 08:02am 03 May 2019
Thanks guys, I take your point.
It was the nature of the error message that had me confused! I will try a different name and see what happens.
Phil
Posted: 10:52am 03 May 2019
As a point of note here, going from what the other guys have said, It is a good habit to get into to never use variable/constant/Sub/Function names that conflict with reserved words. I have found all manner of madnesses down that path over the years. As you have seen here, a badly confused firmware rarely gives useful error messages. This simple rule I have found restores error message usability
my 2pEdited by CaptainBoing 2019-05-04
