Local Time 14:46 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : sprites on E100
antf70
Posted: 06:21am 26 Apr 2019
Probably my novice confusion but is there SPRITE Function/ capability on E100 with SSD1963 display running Micromite Plus MMBasic Ver 5.05.01?
antf70
Posted: 06:44am 26 Apr 2019
PS. Tried the graphics test which said -Function sprite available but no sprite test seen.
Posted: 06:54am 26 Apr 2019
  Quote  Probably my novice confusion but is there SPRITE Function/ capability on E100 with SSD1963 display running Micromite Plus MMBasic Ver 5.05.01?
No: only on some of my various ports
  Quote  PS. Tried the graphics test which said -Function sprite available but no sprite test seen.
This just means the sprite files are available on the SDcard but the graphics test knows that sprites aren't available on the MM+ so doesn't try to run them
