Local Time 13:46 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMEdit Request
Chopperp
Posted: 12:15pm 29 Mar 2019
Hi TassyJim,
Is it possible for the files in MM File Master (PC window) to be sorted by date as well as alphabetically?
This would help to see what files especially library files have been updated. It would also save having a Windows Explorer window open.
Brian
ChopperP
Posted: 08:30pm 29 Mar 2019
I is possible but requires a redesign of the window to fit the extra data in.
I will keep it in mind for when I redo the terminal/file manager.
Chopperp
Posted: 09:13pm 29 Mar 2019
Thanks Jim, much appreciated.
Brian
ChopperP
goc30
Posted: 01:47am 30 Mar 2019
I use this topic to make two requests.
1 - when I click the ALT key (without other key) on editor window, it launch the module "Report" but not each time (it is only when, after download your prog and have Chat window, you add text like adress mail)
2 - when you come from another app, and you click in the window's editor, it is not active, you must clik a second time to make it active. And when we use the copy / paste, often we think we have put the buffer in the editor and not at all.
Turbo46
Posted: 04:34am 30 Mar 2019
Hi goc30,
Your second issue has been raised before, see here - we just have to remember to click twice when coming back to MMEdit.
Posted: 04:50am 30 Mar 2019
Hi goc30,
I don't have the first problem but the second one really annoys me.
Both are caused by the way the editor control is handled by the main program. It is a limitation of LibertyBasic and I have tried many times to find a way around it.
One day I will change over to a different programming language but there is no time frame.
Sorry,
goc30
Posted: 06:02am 30 Mar 2019
Hi TassyJim
thank you for the answers
I asked these questions but I was worried that these are problems coming from your compiler
I don't know why but I was convinced that you had to develop the program with purebasic
Posted: 07:26am 30 Mar 2019
PureBasic is what I will be changing to (eventually)
Any new work is done in PureBasic but it is a big exercise to redoo MMEdit fully.
