Local Time 13:46 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Error problem
palcal
Posted: 05:30am 27 Mar 2019
I have some code that has been running OK and I decided to add GPS time, so I connected the receiver and copy/pasted Geoff's code which runs OK in another project.
I get the error
  Quote  > run
[134] GetMins = GetMins + (md(mth) * (24 * 60))
Error: MD already declared
I did a search and there are only three instances of "MD" in the code the first two here
Dim md(12), arg$(20)
Data 0, 31, 59, 90, 120, 151, 181, 212, 243, 273, 304, 334
For i = 1 To 12: Read md(i): Next i
and the next one in this function.
Function GetMins(yr, mth, day, hr, min)
GetMins = (yr - 14) * (365 * 24 * 60) + ((yr - 13) \ 4) * (24 * 60)
GetMins = GetMins + ((day - 1) * (24 * 60))
GetMins = GetMins + (hr * 60)
GetMins = GetMins + min
If (yr - 16) Mod 4 = 0 And mth > 2 Then GetMins = GetMins + (24 * 60)
End Function
What does this error mean?
Turbo46
Posted: 06:36am 27 Mar 2019
Deleted - sorry mis=read the code.Edited by Turbo46 2019-03-28
Posted: 04:09pm 27 Mar 2019
hi Pascal,
Looks like md() is not locally found in function GetMins(xxxx)
Then the function wants to create it (like any variable that is not known previous) and sees that it already exists.
Is there any way to decare md() globally, or pass it to the function also?
goc30
Posted: 06:49pm 27 Mar 2019
hi paslcal
I have same pb
I have change 2 vars md and arg$ to vmd and varg$
and it work correctly
after, i have bug with "getdate' function, but it is because function is wrong
(pb with computing "day"
I search!!
palcal
Posted: 08:55pm 27 Mar 2019
@goc30
I did the same thing with the same result.
@Volhout
OK now I understand what is happening but md(12) is declared as a global at the start of the code.
disco4now
Posted: 09:47pm 27 Mar 2019
Do you have/need OPTION EXPLICIT
F4 H7FotSF4xGT
Turbo46
Posted: 09:59pm 27 Mar 2019
From Geoff's "SuperClock":
Dim Integer md(12) = (0, 0, 31, 59, 90, 120, 151, 181, 212, 243, 273, 304, 334)
and
' calculate the seconds since midnight 1st Jan 2014
Function GetSec(yr As Integer, mth As Integer, day As Integer, hr As Integer, min As Integer, sec As Integer) As Integer
GetSec = (yr - 14) * (365 * 24 * 60)
GetSec = GetSec + ((yr - 13) \ 4) * (24 * 60)
GetSec = GetSec + (md(mth) * (24 * 60))
GetSec = GetSec + ((day - 1) * (24 * 60))
GetSec = GetSec + (hr * 60)
GetSec = ((GetSec + min) * 60) + sec
If (yr - 16) Mod 4 = 0 And mth > 2 Then GetSec = GetSec + (24 * 3600)
End Function
These are the only places that md() appears and, OK, the code is a bit different but I don't see why one works and the other doesn't. Unless it's a different version of MMBasic and there is a bug.
You don't say which version of MMBasic you are using or what device. I'm not familiar with any of Peter M's versions.
palcal
Posted: 03:19am 28 Mar 2019
MX170 and V5.0409
I don't know what to do? I changed this
to this
and that seemed to fix that part but then got the same error with 'TIMEZONE'
so I substituted 'TIMEZONE' with 10 and got past that, then got the same problem with the Daylight Saving so commented that out then got the problem with the next variable.
I am going to have to go back to the working code I had before trying to add the GPS TIME and start again.
I can't help thinking it has got something to do with the copy/paste of the code.
Edit.... I tried using OPTION EXPLICIT, I declared all the vars but the error still surfaced. I'll START AGAIN.
Edited by palcal 2019-03-29
Turbo46
Posted: 05:53am 28 Mar 2019
Have you considered re-flashing the chip? I think it was Grogster who said recently "When weird stuff happens try re-flashing the chip" or words to that effect. It has worked for others. I'd give it a go.
palcal
Posted: 09:07am 28 Mar 2019
Good idea, I will try that.
palcal
Posted: 02:20am 29 Mar 2019
I re flashed the chip, problem still there BUT since reinstalling MMedit to fix another problem I was having with SEARCH everything seems to be OK. My MMedit must have got corrupted somehow and caused a lot of weird problems.
