Local Time 14:00 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Numberbox change?
CircuitGizmos
Posted: 09:30pm 23 Mar 2019
Did the operation of the numberbox change recently?
I had this code:
GUI NUMBERBOX #2,0,100,150,60,rgb(RED),rgb(BLACK)
GUI BUTTON #3,"Cancel",0,300,150,60,rgb(RED),rgb(WHITE)
DO
Pause 100
LOOP WHILE CTRLVAL(#2) = 0 AND CTRLVAL(#3) = 0
PRINT CTRLVAL(#2)
And CTRLVAL(#2) used to remain 0 until the enter on the numberbox was touched. Now it equals whatever digit is touched.
In other words, it stayed 0 until all 4 (or whatever number) digits PLUS ENTER were touched on the numberbox.
disco4now
Posted: 11:19pm 23 Mar 2019
5.05.01 ChangeLog has these notes. They indicate something has changes in this area.
Fixed a bug which caused the CtrlVal() function to return an incorrect value for a
NUMBERBOX or TEXTBOX when called from within the MM.KEYPRESS subroutine.
As part of the above fix CtrlVal() will always return a floating point value for
NUMBERBOX - even within the MM.KEYPRESS subroutine (previously it was
documented as returning a string inside this sub).
F4 H7FotSF4xGT
CircuitGizmos
Posted: 12:21am 24 Mar 2019
Lets say a number box has a value in it. The user wants to change that value. The software would want to do something now that the value has changed. I expected that the "change" would happen when the user was done entering the complete number on the popup keypad, not as each digit was being entered. When would I know that the user is done?
KeepIS
Posted: 01:48am 24 Mar 2019
I've been using the number box for a while and just checked it again. It correctly shows each number pressed on the keypad in the number box control, which is logical as the user needs to verify the key pressed, however I can remember in the past that even though each keypress was shown in the control, the control returned 0 if you read it before the Ent key was pressed, so from memory, it appear to have changed it's behaviour slightly, however I use MM.KEYPRESS to set a flag when the Ent key is pressed for that control and process the control value in the main loop once the flag is set. Most likely why I hadn't noticed the change before.
SUB MM.KEYPRESS(KREF AS INTEGER, CAPVal$ AS STRING)
Select CASE KREF
CASE JOBS_TBOX
IF CAPVal$ = "Ent" THEN
ELSE
DoKeyPress(CAPVal$,1)
ENDIF
CASE JOBS_DCPT
ELSE
DoKeyPress(CAPVal$,2)
ENDIF
CASE NumBOX_JOBS
JOBKpadClosed = 1
ButtonTouched = DO_JOBS_Kpad
ENDIF
CASE NumBox_MoveFenceVal
ButtonTouched = DO_MoveFence_Kpad
ENDIF
END SELECT
END SUB
I use DoKeyPress(CAPVal$,2) for the textbox to check each char entered and limit the string length to stop text writing past the end of the control.
Edited by KeepIS 2019-03-25
NANO:Inverter V 8.4ksLinux AvrDude GUI script V4.1
