Local Time 14:28 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : A bug report?
Malibu
Posted: 04:46am 19 Mar 2019
G'day everyone
I've been playing around with a few new (new to me, anyway) functions in MM+ and maybe stumbled across a couple of bugs...
Here's the whittled down code to make it easier...
Option autorun on
OPTION EXPLICIT
dim Value=pi '<Gives value of 3.141592741, should be 3.141592653
cls
GuiSetup
page 1
sub GuiSetup
gui setup 1
font 4
gui displaybox #1,5,5,310,90,rgb(black),RGB(cyan)
gui displaybox #2,5,100,310,90,rgb(black),RGB(cyan)
ctrlval(1)=str$(Value),0,5 'A syntax error, but does not flag a fault
ctrlval(2)=str$(Value,0,5) 'Works correctly
end sub
Bug 1)
I selected PI as my number because it's a good number that I didn't need to type in... it's already there.
I remember PI to 7 decimal places from school days, so this value didn't look correct. I'm pretty sure it's not, but I'm happy to be proved wrong
Bug 2)
CtrlVal(1) line was a coding typo on my part, which MM happily ignored when it was running. CtrlVal(2) line is what I was trying to achieve with rounding to 5 decimal places.
Should CtrlVal(1) line have flagged a fault during run-time because the closing bracket is in the wrong position (which means what comes after is not valid code), or is it actually a valid bit of coding?
(Sorry, I meant to say it's MM Basic Ver 5.04.10)Edited by Malibu 2019-03-20
Posted: 06:24am 19 Mar 2019
It looks like PI is stuck as single precision.
MMBasic V5.4.10 should be double precision and in V5.5.1 PI is defined as
#define PI_VALUE 3.14159265358979323
I don't know C anywhere well enough to say why it looses precision.
  Quote  myPi = 3.141592653589793238'462643532127
PRINT STR$(myPi,3,15)
PRINT STR$(PI,3,15)
> RUN
3.141592653589793
3.141592741012573
I don't know graphics programming well enough to comment on the other problem.
