Local Time 14:20 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : E100 SD and RTC modules
Tinine
Posted: 01:28am 23 Feb 2019
I have been looking for direct pin-compatible modules without luck.
Anyone have a source for these, please?
Edit: Correction. I did locate the RTC. Just the SD module that I need. Edited by Tinine 2019-02-24
palcal
Posted: 04:09am 23 Feb 2019
Grogster's web site (Rictech NZ) has a bill of materials for the E-100 in the download section.
Tinine
Posted: 04:44am 23 Feb 2019
  palcal said   Grogster's web site (Rictech NZ) has a bill of materials for the E-100 in the download section.
Thanks palcal.
I purchased my E-100s fully assembled and they have headers for optional modules. I have found many SD card modules on eBay but none with the same pin assignments as the E-100s header, "C10".
Posted: 06:26am 23 Feb 2019
CON10 is the old SD-card connector, when the board did not have and SD card on it, as it used the SD card socket on the LCD module. But if you were not using an LCD module, you were kinda stuck.
I expect you have 1B version of the board then. 1C's and 1D's have a micro-SD card slot on-board.
I used to sell an SD add-on kit for CON10 on the earlier boards, but once the later boards were being made, I took that off the site. Please PM me, and I can arrange to have one sent to you.
Tinine
Posted: 06:56am 23 Feb 2019
DOH! I was on your site, earlier because I thought I'd read somewhere about the CON10 module....didn't think to check for a new E-100 version...very nice indeed
