Local Time 14:27 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem with ESP-01 ESP8266 & Nucleo-L432
Posted: 02:14am 17 Feb 2019
I had previously run the MM2+ESP-01 webserver posted by matherp here:
MM2: webserver with AT mode ESP8266
I'm trying to port it to the Nucleo-L432KC on a breadboard with a breakout board for the ESP-01. I can connect to wifi with the modified program, so there is successful communication with the ESP-01, but the program never gets back an ungarbled HTTP response.
I've connected RX on a CH340 USB/serial module to RX on the Nucleo board, and I can see that the HTTP response from the ESP-01 is perfectly OK, e.g.,
[code]
+IPD,0,359:GET /favicon.ico HTTP/1.1
Host: 192.168.1.210:1234
Connection: keep-alive
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/72.0.3626.109 Safari/537.36
Accept: image/webp,image/apng,image/*,*/*;q=0.8
Referer: http://192.168.1.210:1234/
Accept-Encoding: gzip, deflate
Accept-Language: en-US,en;q=0.9
[/code]
This is an example of what the program prints:
[code]
nparams: 0: ||
Z!Q51± like Gecko) Chrome/72.0.3626.109 Safari/537.36
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8
[/code]
(This is at 9600 baud. It was much more garbled at the baud rate where I started, 115200, though the connection to wifi worked at that baud rate.)
If I force the parsed input to be "INDEX", the web page is presented perfectly (at, on my system, http://192.168.1.210:1234/ in the chrome browser).
I don't have any sensors on the breadboard at present. My ESP-01 RX & TX connections to the nucleo board are to D1 USART1-TX and D0 USART1-RX, respectively.
What am I doing wrong?
(Code attached.)
2019-02-17_121201_ATWIFI-esp8266_L4x.zip Edited by lizby 2019-02-18
Posted: 04:58pm 17 Feb 2019
Essentially the same program works on the H7, mm.ver=5.05.03, except that there is a continual non-terminating error relating to the AT command "CIPSEND" (which I've ignored), and there is some chatter from the ESP-01 which I haven't yet been able to filter out (just starting to try).
There is also a terminating error with TEMPR START followed by TEMPR (but that may be the result of having no DS18B20 attached).
Other than that, the html page is rendered properly with the H7. This is with the ESP-01 set at 9600 baud. At other speeds (57600 & 115200) I haven't gotten reliable responses.
Edited by lizby 2019-02-19
Posted: 08:33am 18 Feb 2019
I'm trying to replicate but struggling with my ESP-01 which I updated to the latest release and am having a problem with CIPSEND which is only working once even using the original MM2 code.
On the H7 I can connect and I can receive the page request perfectly well at 115200 baud. Make sure you are using the very latest H7 firmware and most importantly check the power supply to the ESP. They are very hungry and very noisy. On my backpack I feed a 100uF capacitor in series with a 0.1uF cap through a 2R2 resistor to isolate the ESP.
On the L4 make sure of the power supply and then try removing all pause statements from the code. During pauses on the L4 the CPU clock is set down to 2MHz to save power and it may be possible that at this speed the CPU is too slow to buffer the incoming data. I'll try and check this later today and if necessary change the code to leave the CPU speed if a com port is active. The port itself works on a different clock so isn't impacted by CPU speed changes.
UPDATE
Please try this version on the L4, This doesn't slow the CPU during pause if one of the com ports is active. Works for me at 115200.
2019-02-18_202911_ArmmiteL4.zip
UPDATE UPDATE
For reasons I don't understand Chrome doesn't like port 1234. This code is tested on an L4 using above release and port 80 and works properly at 115200. Code includes lots of diagnostic prints
Option explicit
option default NONE
const MaxLen=4096
const max=20
' Global variables
const quote=chr$(34)
CONST SSID$=quote+"mySSID"+quote
CONST SSIDPassword$=quote+"myPASSWORD"+quote
const starttext$="HTTP"
const pnf$="<html><body>Page not Found</body></html>"
const title$="<html><head><title>Remote Thermostat</title></head><body>"
const ending$="</form></body></html>"
const form$="<form name='f1' method='get' action='D'>"
const h2$="<h2 align='left'>Remote Thermostat V3.0</h2>"
const code$="Update Code: <input type='text' name='S' size='6' value='000000'><br>"
const tstart$="<p><TABLE BORDER='1' CELLSPACING='0' CELLPADDING='5'>"
const heat$="<TR><TD>Heating</TD>"
const hon$="<TD BGCOLOR='#ff0000'> On</TD></TR>"
const hoff$="<TD BGCOLOR='#00ff00'>Off</TD></TR>"
const tend$="</TABLE></p>"
const h3$="<TR><TD></TD><TD>Temperature</TD></TR>"
const s1$="<TR><TD>Current</TD><TD>"
const s2$="<TR><TD>Max</TD><TD>"
const s3$="<TR><TD>Min</TD><TD>"
const check$="<input name='C' type='checkbox' value='R' onClick='this.form.submit()'> Reset Max/Min"
const s4$="<TR><TD>Thermostat</TD>"
const s5$="<TD><input name='R' type='radio' checked='checked' value='"
const s6$="<TD><input name='R' type='radio' value='"
const click$=" 'onClick='this.form.submit()'> "
const degree$="°C<br></TD>"
const offstr$="Off<br></TD>"
const onstr$="On<br></TD>"
const ON=1
const off=0
' Set up parameters
const starttemp=20 'set the lowest temperature on the thermostat select radio buttons
const hysteresis=2 ' 2 tenths of a degree either side of the setpoint
const waittime=1000 'wait time in readrequest before timeout
const password$="123456" 'password to access change mode
const dspin=28
const relaypin=26
Dim arg$(2,max) length 20
DIM integer inbuf(Maxlen\8) 'global input buffer
dim string CRLF=chr$(13)+chr$(10) length 2
dim integer IPDno 'global IPD numbers used to ensure transmit is on correct IPD
dim integer heater,currenttemp,maxtemp,mintemp,setpoint
dim integer nparams
dim mypage$ 'variables used by main loop only
DIM obuff$="" 'used to buffer writes to the internet to optimise speed
Init:
TEMPR start dspin,3 'measure temp to 0.0625 degree accuracy
mintemp=1000 'set to silly value to force reset if not saved
maxtemp=-1000
currenttemp=cint(TEMPR(dspin)*10)
TEMPR start dspin,3
var restore 'recover the setpoint and min and max temps if already saved
maxmin 'update the maximum and minimum and save them if changed
heater=off
pin(relaypin)=heater
setpin relaypin,dout
setpoint=asc("E")
pause 2000 'wait for ESP8266 to wake up afer power on
open "com1:115200,4096" as #1
close #1 'clear the buffer
IF NOT Command("AT",500) THEN END
IF NOT Command("AT+RST",10000,"WIFI GOT IP") THEN 'reset and check for valid connection
PRINT "Set up WIFI on SSID: ",SSID$
IF NOT Command("AT+CWMODE_DEF=1",5000) THEN END 'set device mode (1=client, 2=AP, 3=both)
IF NOT Command("AT+CWLAP",30000) THEN END 'scan for WiFi hotspots
longstring print inbuf() 'output the list of valid networks
IF NOT Command("AT+CWJAP_DEF="+SSID$+","+SSIDPassword$,20000,"WIFI GOT IP") THEN END 'connect
IF NOT Command("AT+CIFSR",5000) THEN END 'check IP address
ENDIF
IF NOT Command("AT+CIPMUX=1",5000) THEN END
IF NOT Command("AT+CIPSERVER=1,80",5000) THEN END
Print "Connected"
IF NOT Command("AT+CIPSTATUS",30000) THEN END 'scan for WiFi hotspots
main:
DO
updateheater
TEMPR start dspin,3
if ReadRequest(waittime) then 'process HTML request
mypage$=ucase$(parsehtmldata$(nparams)) 'parse the html request and get the page requested
if mypage$<>"" then 'real request so do something
if mypage$= "INDEX" then
drawpage
elseif mypage$="D" then
if nparams<>0 then 'we have parameters to process
if arg$(0,0)="S" and arg$(1,0) = password$ then
if arg$(0,1)="C" and arg$(1,1)="R" then 'reset the max min to current
maxtemp=currenttemp
mintemp=currenttemp
var save setpoint,maxtemp,mintemp
endif
if arg$(0,1)="R" then 'change the setpoint and update the heater if applicable
setpoint=asc(arg$(1,1))
updateheater
endif
endif
endif
drawpage
else
SendText pnf$+crlf+crlf'invalid page
endif
EndSend 'clear the write buffer and terminate the write
endif
endif
LOOP
end
Function parsehtmldata$(paramcount as integer) as string
local a$,b$
local integer buf(Maxlen\8)
local integer inpos,startparam,processargs
paramcount=0
inpos=lInstr(inbuf(),"GET /",1)
if inpos=0 then
parsehtmldata$=""
else
longstring RIGHT buf(),inbuf(),inpos+5
inpos=lInstr(buf(),starttext$,1)
If inpos>2 Then 'page request found
inpos=inpos-2
a$=lGetStr(buf(),1,inPos)
inpos=Instr(a$,"?")
If inpos<>0 Then 'parameters found
processargs=1
parsehtmldata$=Left$(a$,inpos-1)
a$=Mid$(a$,inpos+1)
arg$(0,paramcount)=""
arg$(1,paramcount)=""
inpos=Instr(a$,"=")
startparam=1
arg$(0,paramcount)=Mid$(a$,startparam,inpos-startparam)
startparam=inpos+1
inpos=Instr(a$,"&")
If inpos<>0 Then
arg$(1,paramcount)=Mid$(a$,startparam,inpos-startparam)
a$=Mid$(a$,inpos+1)
paramcount=paramcount+1
Else
arg$(1,paramcount)=Mid$(a$,startparam)
processargs=0
EndIf
Loop while processargs
Else
parsehtmldata$=a$
EndIf
Else ' no page requested
parsehtmldata$="INDEX"
EndIf
endif
End Function
sub maxmin
local integer update=off
if currenttemp>maxtemp then
maxtemp=currenttemp
update=on
endif
if currenttemp<mintemp then
mintemp=currenttemp
update=on
endif
if update then var save setpoint,maxtemp,mintemp
end sub
sub updateheater
local integer hcalc
if setpoint=asc("L") then
pin(relaypin)=ON
heater=on
endif
if setpoint=asc("A") then
pin(relaypin)=OFF
heater=oFF
endif
if setpoint>=asc("B") and setpoint<=asc("K") then
hcalc=(setpoint-asc("B")+starttemp)*10 'setpoint temperature * 10
hcalc = hcalc + hysteresis
if currenttemp>=hcalc then 'turn heating off
pin(relaypin)=OFF
heater=oFF
endif
hcalc = hcalc - hysteresis - hysteresis
if currenttemp<=hcalc then 'turn heating on
pin(relaypin)=ON
heater=oN
endif
endif
end sub
sub drawpage
local integer loopcounter,tempconvert
local b$
sendText title$+form$+h2$+code$
sendText tstart$+heat$
if heater then
sendText hon$+tend$
else
sendText hoff$+tend$
endif
sendText tstart$
sendText h3$
b$=s1$+outtemp$(currenttemp)+degree$
b$=b$+s2$+outtemp$(maxtemp)+degree$
b$=b$+s3$+outtemp$(mintemp)+degree$
sendText b$
sendText tend$
sendText check$
sendText tstart$
sendText s4$
for loopcounter=asc("A") to asc("L")
if loopcounter=setpoint then
sendText s5$+chr$(loopcounter)
else
sendText s6$+chr$(loopcounter)
endif
sendText click$
tempconvert=loopcounter-asc("B")+starttemp
if loopcounter>asc("A") and loopcounter<asc("L") then sendText str$(tempconvert,2)+degree$
if loopcounter=asc("A") then sendText offstr$
if loopcounter=asc("L") then sendText onstr$
next loopcounter
sendText tend$
sendText ending$+crlf+crlf
end sub
function outtemp$(t as integer)
local integer tenths=t mod 10
local integer units= t\10
outtemp$=str$(units,3)+"."+chr$(tenths+48)
end function
sub EndSend
local b$
b$="AT+CIPSEND="+CHR$(IPDno+48)+","+STR$(len(obuff$)) 'send anything still in the buffer
IF NOT Command(b$,500,">") THEN
if lInstr(inbuf(),"link is not valid") then exit sub
endif
IF NOT Command(obuff$,500) THEN END
IF NOT Command("AT+CIPCLOSE="+CHR$(IPDno+48),500) THEN
if lInstr(inbuf(),"UNLINK") then
obuff$=""
exit sub
else
end
endif
endif
obuff$=""
end sub
sub SendText(a$)
local b$
if len(a$)+len(obuff$)< 240 then 'add the new string to the output buffer
obuff$=obuff$+a$
else 'too big to fit so send the current output buffer
IF NOT Command(b$,1000,">") THEN
if LInstr(inbuf(),"link is not valid") then
print "link is not valid"
exit sub
endif
endif
print obuff$
IF NOT Command(obuff$,2000) THEN END
obuff$=a$
endif
end sub
FUNCTION ReadRequest(timeout%) as integer
ReadRequest=0
longstring Clear inbuf()
timer=0
do while TIMER<timeout% and LOC(#1)=0
loop
pause 50
if TIMER>=timeout% then exit function
do while loc(#1)<>0
longstring append inbuf(),input$(min(255,loc(#1)),#1)
loop
if (NOT lInstr(inbuf(),"favicon",0)) and (NOT lInstr(inbuf(),"CONNECT FAIL",1)) then ReadRequest=1 'junk the favicon requests and disconnects
IF lInstr(inbuf(),"IPD,0",1) then
IPDno=0
print "IPDno = ",IPDno
endif
IF lInstr(inbuf(),"IPD,1",1) then
IPDno=1
endif
end function
end sub
FUNCTION Command(AT$, timeout%, other$) as integer 'send a command and wait for the answer
local i%=0,j%,ex%=0
Local a$
Command=0
print #1,AT$+crlf;
TIMER=0
i%=0
do
if TIMER>timeout% then
ex%=0
EXIT DO
endif
j%=LOC(#1)
if j%>0 then
i%=i%+min(255,j%)
longstring append inbuf(),input$(min(255,j%),#1)
if llen(inbuf())>4 and other$="" then
if lInstr(inbuf(),"OK",1) then
ex%=1
exit DO
endif
endif
if llen(inbuf())>7 then
if lInstr(inbuf(),"ERROR",1) then
ex%=2
exit DO
endif
endif
if llen(inbuf())>len(other$)+2 then
if lInstr(inbuf(),other$,1) then
ex%=3
exit DO
endif
endif
endif
loop
select case ex%
case 0
Print "Timeout : "+AT$
case 1
Command=1
case 2
Print "ERROR : "+AT$
case 3
Command=1
end select
end function
Edited by matherp 2019-02-19
Posted: 03:26pm 18 Feb 2019
Thank you very much for this. I have a day trip planned for today, so probably won't get to it until this evening or tomorrow.
I also had upgraded the ESP-01 to the latest firmware.
Posted: 06:39pm 18 Feb 2019
Here is an optimisation that uses "longstring print #n" to send the data after a CIPSEND. This allows us to use the maximum 2048 bytes allowed which reduces the number of sends.
Option explicit
option default NONE
const MaxLen=4096
const max=20
' Global variables
CONST SSID$=quote+"TOASTY2"+quote
CONST SSIDPassword$=quote+"Testthewater01"+quote
const ON=1
const off=0
' Set up parameters
const dspin=25
const relaypin=26
DIM integer inbuf(Maxlen\8), outbuf(2048/8-1) 'global input and output buffers
dim integer nparams
Init:
maxtemp=-1000
TEMPR start dspin,3
heater=off
setpoint=asc("E")
pause 2000 'wait for ESP8266 to wake up after power on
ENDIF
Print "Connected"
longstring clear outbuf()
main:
DO
updateheater
TEMPR start dspin,3
drawpage
maxtemp=currenttemp
mintemp=currenttemp
endif
updateheater
endif
endif
endif
drawpage
else
endif
endif
endif
LOOP
end
local a$,b$
local integer buf(Maxlen\4) ' long string
paramcount=0
inpos=LInstr(inbuf(),"GET /",1)
if inpos=0 then
parsehtmldata$=""
else
LONGSTRING MID buf(),inbuf(),inpos+5, llen(inbuf())-(inpos+5)
inpos=LInstr(buf(),starttext$,1)
inpos=inpos-2
a$=LGetStr$(buf(),1,inPos)
inpos=Instr(a$,"?")
processargs=1
a$=Mid$(a$,inpos+1)
inpos=Instr(a$,"=")
startparam=1
startparam=inpos+1
inpos=Instr(a$,"&")
If inpos<>0 Then
a$=Mid$(a$,inpos+1)
Else
processargs=0
EndIf
Else
parsehtmldata$=a$
EndIf
EndIf
endif
End Function
sub maxmin
maxtemp=currenttemp
update=on
endif
mintemp=currenttemp
update=on
endif
end sub
sub updateheater
local integer hcalc
pin(relaypin)=ON
heater=on
endif
pin(relaypin)=OFF
heater=oFF
endif
pin(relaypin)=OFF
heater=oFF
endif
pin(relaypin)=ON
heater=oN
endif
endif
end sub
sub drawpage
local b$
if heater then
sendText hon$+tend$
else
endif
sendText tstart$
sendText h3$
sendText b$
sendText tend$
sendText check$
sendText tstart$
sendText s4$
else
endif
sendText click$
next loopcounter
sendText tend$
end sub
end function
sub EndSend
local b$
b$="AT+CIPSEND="+CHR$(IPDno+48)+","+STR$(llen(outbuf()))
exit sub
endif
endif
IF NOT senddata(5000) THEN END
exit sub
else
end
endif
endif
end sub
sub SendText(a$)
local b$
if len(a$)+llen(outbuf())< 2048 then 'add the new string to the output buffer
longstring append outbuf(),a$
exit sub
endif
endif
endif
end sub
ReadRequest=0
timer=0
loop
pause 50
do while loc(#1)<>0
loop
IPDno=0
endif
IPDno=1
endif
end function
end sub
FUNCTION senddata(timeout%) as integer 'send a command and wait for the answer
local i%=0,j%,ex%=0
Local a$
senddata=0
longstring print #1,outbuf();
TIMER=0
i%=0
do
ex%=0
EXIT DO
endif
j%=LOC(#1)
if j%>0 then
i%=i%+min(255,j%)
if llen(inbuf())>4 then
ex%=1
exit DO
endif
endif
ex%=2
exit DO
endif
endif
endif
loop
select case ex%
case 0
Print "Timeout in CIPSEND data"
case 1
senddata=1
case 2
Print "ERROR in CIPSEND data"
end select
end function
local i%=0,j%,ex%=0
Local a$
Command=0
print #1,AT$+crlf;
TIMER=0
i%=0
do
ex%=0
EXIT DO
endif
j%=LOC(#1)
if j%>0 then
i%=i%+min(255,j%)
ex%=1
exit DO
endif
endif
ex%=2
exit DO
endif
endif
ex%=3
exit DO
endif
endif
endif
loop
select case ex%
case 0
case 1
Command=1
case 2
case 3
Command=1
end select
end function
Edited by matherp 2019-02-20
Posted: 02:17am 19 Feb 2019
Thank you very much, Peter. It works for me.
I made a few modifications to print some stuff, including the IP address. I had to add back in the RESTART toggle (though perhaps I should try that again now that everything is working).
I am able to run it powered off of the 3.3V line on the Nucleo board. That might not work for all and might not work for me in other circumstances.
I'm downloading with XMODEM Transfer Send from TeraTerm. (When I tried pasting it in after AUTOSAVE, after some dozens of lines it started clipping off the first character, making, for instance, "UNCTION Command" not work.)
Here is what works for me with CHPD pulled high with 10K the only ESP-01 connections except for 3V3, 0V, RST, RX, & TX.
[code]
Option explicit
option default NONE
const MaxLen=4096
const max=20
' Global variables
CONST SSIDPassword$=quote+"myPassword"+quote
const ON=1
const off=0
' Set up parameters
const dspin=15 ' 25
const relaypin=14 ' 26
const resetpin=6 ' L4=6 ' a0 45
dim integer nparams, ipos, jpos
Init:
print("Starting")
setpin resetpin,dout
pin(resetpin)=0 'put the ESP8266 into reset
maxtemp=-1000
TEMPR start dspin,3
heater=off
setpoint=asc("E")
pin(resetpin)=1 'release the ESP8266 from reset
pause 500
' open "com1:9600,4096" as #1
print "Opening COM1"
IF NOT Command("AT+CWJAP_DEF="+SSID$+","+SSIDPassword$,30000,"WIFI GOT IP") THEN END 'connect
' IF NOT Command("AT+CWJAP_DEF="+SSID$+","+SSIDPassword$,20000,"WIFI CONNECTED") THEN END 'connect
ENDIF
print "Getting IP: ";
IF Command("AT+CIFSR",5000) THEN 'check IP address
iPos=LInstr(inbuf(),quote,1) ' opening quote
if iPos > 0 then
jPos=LInstr(inbuf(),quote,iPos+1) ' closing quote
if jPos > 0 then
print LGetStr$(inbuf(),iPos+1,jPos-iPos-1)
endif
endif
endif
Print "Connected"
main:
DO
updateheater
TEMPR start dspin,3
drawpage
maxtemp=currenttemp
mintemp=currenttemp
endif
updateheater
endif
endif
endif
drawpage
else
endif
endif
endif
LOOP
end
local a$,b$
paramcount=0
if inpos=0 then
parsehtmldata$=""
else
inpos=inpos-2
inpos=Instr(a$,"?")
processargs=1
a$=Mid$(a$,inpos+1)
inpos=Instr(a$,"=")
startparam=1
startparam=inpos+1
inpos=Instr(a$,"&")
If inpos<>0 Then
a$=Mid$(a$,inpos+1)
Else
processargs=0
EndIf
Else
parsehtmldata$=a$
EndIf
EndIf
endif
End Function
sub maxmin
maxtemp=currenttemp
update=on
endif
mintemp=currenttemp
update=on
endif
end sub
sub updateheater
local integer hcalc
pin(relaypin)=ON
heater=on
endif
pin(relaypin)=OFF
heater=oFF
endif
pin(relaypin)=OFF
heater=oFF
endif
pin(relaypin)=ON
heater=oN
endif
endif
end sub
sub drawpage
local b$
if heater then
sendText hon$+tend$
else
endif
sendText tstart$
sendText h3$
sendText b$
sendText tend$
sendText check$
sendText tstart$
sendText s4$
else
endif
sendText click$
next loopcounter
sendText tend$
end sub
end function
sub EndSend
local b$
exit sub
endif
endif
exit sub
else
end
endif
endif
end sub
sub SendText(a$)
local b$
exit sub
endif
endif
endif
end sub
ReadRequest=0
timer=0
loop
pause 50
do while loc(#1)<>0
loop
IPDno=0
endif
IPDno=1
endif
end function
end sub
local i%=0,j%,ex%=0
Local a$
senddata=0
TIMER=0
i%=0
do
ex%=0
EXIT DO
endif
j%=LOC(#1)
if j%>0 then
i%=i%+min(255,j%)
ex%=1
exit DO
endif
endif
ex%=2
exit DO
endif
endif
endif
loop
select case ex%
case 0
case 1
senddata=1
case 2
end select
end function
local i%=0,j%,ex%=0
Local a$
Command=0
print #1,AT$+crlf;
TIMER=0
i%=0
do
ex%=0
EXIT DO
endif
j%=LOC(#1)
if j%>0 then
i%=i%+min(255,j%)
ex%=1
exit DO
endif
endif
ex%=2
exit DO
endif
endif
ex%=3
exit DO
endif
endif
endif
loop
select case ex%
case 0
case 1
Command=1
case 2
case 3
Command=1
end select
end function
[/code]
Edited by lizby 2019-02-20
