Local Time 14:12 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite CPU Exception Error
subalib
Posted: 08:30am 12 Feb 2019
I have been experimenting with CPU speeds on the Micromite Plus 100. Specifically at the start of a program. I inadvertently set CPU 120 at the start of a program and now all I get is a string of CPU Exception errors before it displays CPU restarted. Unfortunately it seems to be locked up at this point and does not display the command prompt to allow me to redit the program.
Any help would be appreciated. Thanks
Posted: 09:34am 12 Feb 2019
Micromite manual - page 16 for how to reset
Posted: 09:35am 12 Feb 2019
Check out the section "Resetting MMBasic" on page 16 of the Micromite User Manual which can be downloaded from here: http://geoffg.net/micromite.html (scroll to the bottom of the page).
subalib
Posted: 10:07am 12 Feb 2019
Thank you. All sorted. I must have missed that page while reading about the Micromite.
