Local Time 14:04 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : TEMPR=542’C....
Posted: 08:12am 07 Feb 2019
This one is another one I can't work out.
An 18B20 sensor stuck onto a heater plate, 50% of the time, the result returned is correct - about 37'C. The other 50% of the time, the result is ALWAYS 542'C.
I know that cannot be correct, as I doubt I would be alive at 542'C....
Can anyone suggest why that should be?
Relevant code is:
  Quote   Text 220,225,"PLATE="+STR$(CINT(TEMPR(PLATE)))+" ",L,1,1,RGB(Green)
JohnL
Posted: 09:16am 07 Feb 2019
DeletedEdited by JohnL 2019-02-08
Solar Mike
Posted: 09:41am 07 Feb 2019
Hi Grogster, put your scope between 0v and the data line, at the sensor; you may have noise on the wire stuffing up the readings. I had one of these play up awhile ago whenever a 230 vac fan turned on, ended up being induced mains noise, fixed with ferrite chokes.
Mike
Phil23
Posted: 08:04pm 07 Feb 2019
  Grogster said  The other 50% of the time, the result is ALWAYS 542'C.
I've seen occasional errors on mine when the 5V supply is bad or there's interference. But then again mine are on long strings, one exceeding 30m.
542 is a weird result to get though, as it can't be derived from the binary output of the things.
2^6 is the most significant bit, which would allow a maximum reading on 127°C.
I do have a vague recollection of some firmware issue relating to DS18B20's, but think that may have been on ARMs or something.
Posted: 09:47pm 07 Feb 2019
Cool, thanks for the suggestions.
@ JohnL: Deleted. Now you have made me curious as to what you posted. Do tell.
GoodToGo!
Posted: 01:22am 09 Feb 2019
I wonder if it's a calculation error?
542 is 0000 0010 0001 1110 in binary.
According to the datasheet, a valid DS18B20 12 bit reading of that binary number equates to 33.875 degrees.
Food for thought?
Cheers!
GTG!
Posted: 01:57am 09 Feb 2019
Definitely food for thought but I can't see how it's happening.
The relevant bit of code in the firmware (V5.3) is
fret = (float)((short)(((unsigned short)b2 << 8) | (unsigned short)b1)) / 16.0;
Something in the timing that causes a shift of 4 bits to the left?
