Local Time 14:04 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PC Audio Compressor/Limiter...
Posted: 07:26am 04 Feb 2019
I am looking for something along the lines of Volume Logic which I used to use, but now does not seem to be available.
Do any members have any suggestions?
Perfectly happy to pay for it, if it works.
aladdin4d
Posted: 05:08am 05 Feb 2019
Breakaway Audio Enhancer is the direct successor to Volume Logic. Unlike Volume Logic it's Windows only.
For a Mac there's something called Audio Hijack. It's really for capturing any audio but it can be setup to route your audio through an effects chain similar to Volume Logic. I don't know if it's still possible but at one time you could even get it to use the 32 bit Volume Logic as a plugin and apply it to the output of 64 bit iTunes
Posted: 05:12am 05 Feb 2019
Hello and welcome to the forums.
Thank you for your post. This sounds(pun?) just like what I need. Thank you. At US$30, it is also very affordable too. Thanks again.
