Local Time 14:46 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Armmite F7: One off version
Posted: 01:54pm 03 Feb 2019
Please find attached a version of the Armmite software that will work on the STM32H767ZI.
2019-02-03_235354_ArmmiteF7.zip
This was done as a one-off to look at the portability of code on the STM32 range. I will not be maintaining this version going forward but if you happen to have a Nucleo-H767 then you can use this firmware on it.
The firmware uses an internal RC oscillator so can run on the Nucleo with the ST-LINK board detached. Performance is basically equivalent to a MMX at 252MHz.
The port is fully compatible with the Armmite H7 backpack.
Use the Armmite H7 manual for details of the port subject to the changes identified below:
MM.DEVICE$ gives "ARMmite F7"
SPI-CLK on pin 128 and not 126
SETPIN 93,CIN and SETPIN 93,FIN ' not available
SETPIN n, AIN [,bits] ' bits limited to 8,10, and 12
PIN(DACn) ' not available
PIN(TEMP) ' not available
PIN(SREF) ' not available
OPTION USBKEYBOARD ' not available
OPTION FLASHPAGES n ' n can be 1 (default) or 2 giving 256Kb or 512Kb of program space
OPTION LCDPANEL SSD1963_n_BUFF, orientation ' not available
OPTION LCDPANEL SSD1963_n_640, orientation ' not available
CAMERA command ' not available
MOVEMENT function ' not available
Posted: 02:39pm 03 Feb 2019
Any chance this should be Nucleo-F767 etc i.e. H767 -> F767?
Posted: 03:09pm 03 Feb 2019
  Quote  Any chance this should be Nucleo-F767 etc i.e. H767 -> F767?
Yup
Posted: 03:16pm 03 Feb 2019
Thank you for this port to the Nucleo-F series.
What I would really like to see, and would undertake myself if you are willing to share this code, is a port to the NUCLEO-F446RE--64 pins, 512KB flash, 180MHz.
That part seems to me to fill an important slot in the Micromite lineup--an inexpensive ($14.90US at Digikey) 64-pin PCB with the easy access of the ST-LINK connection and enough speed and flash to support gui features.
I know there would be a good many differences from the 144-pin version, but I'm willing to try a port.
NUCLEO-F446RE
gadgetjack
Posted: 03:47am 04 Feb 2019
Can't wait to try this on my board. Thank you for taking the time to even try this port of your code. I can easily live with this being the only update.
Posted: 09:10am 04 Feb 2019
  Quote  What I would really like to see, and would undertake myself if you are willing to share this code, is a port to the NUCLEO-F446RE--64 pins, 512KB flash, 180MHz.
H7 source is available through MMBasic.com. I personally can't see any reason to support STMF4 as there is no significant advantage over MM+ and MMX whereas H7 is MUCH faster and L4 is low power so both bring things the PIC versions can't supplyEdited by matherp 2019-02-05
Posted: 03:23pm 04 Feb 2019
I'd love to see a 64-pin Nucleo board in the H series, and agree that it would make F-series ports superfluous, but as far as I can tell the H-series has only the 144 pinner. So a custom design with display would take the Nucleo-H board, the display backpack, and a custom design.
That's about 140 solder points for the H board, another 140 + components for the display backpack, and another 140 (more or less) plus components and other connectors for the custom board--so probably well in excess of 500 solder points. That may be nothing for many of you, but for this software person, it's daunting.
I'll be happy to try the new port, but didn't bring my F767ZI board when I snowbirded south for the winter, so I won't be able to try it before April.
Posted: 11:08am 06 Feb 2019
If you want to try it, quite cheap to buy another :)
gadgetjack
Posted: 02:33am 08 Mar 2019
Is there any chance this will support an external keyboard so it is not tied to a terminal ? Any kind of keyboard will do. If not , I will find a keyboard to serial converter of some kind , maybe arduino or other small board. It runs great and I am happy as I can be to use this board I ordered wrong during the H7 software release. I just jumped the gun before reading it all the way , kinda my MO. LOL
Posted: 08:51am 08 Mar 2019
  Quote  Is there any chance this will support an external keyboard so it is not tied to a terminal ?
Sorry, but this really is a one-off release. Implementing USB is always a biggish task so not something I want to tackle on the F7 which I won't be supporting as a long term platform.
Bill7300
Posted: 10:39pm 08 Mar 2019
@gadgetjack
As somebody mentioned in a response in another thread a couple of months back, Silicon Chip ran an article on a keyboard and/or mouse serial converter in its February issue. I happened to read that article last night in my catch-up magazine reading after being away for several months. PIC32MX270 based, PCB etc available from the magazine. Should be usable in your application.
gadgetjack
Posted: 11:24pm 08 Mar 2019
I understand not wanting to add the usb to this release , i really do. I will come up with a small micro circuit that will give me the serial input the board needs. Bill7300 suggested a good one and I believe Geoff had a small board that would work ok too. I will go that route. Again , I thank you for writing this one for us. I love to see what you come up with every day when I get on the board. ALl you guys are great to follow.
Jack
Turbo46
Posted: 12:25am 09 Mar 2019
That was probably my post on the Silicon Chip keyboard and/or mouse serial converter. I built the mouse version only and it works well with the maximite. The only difference between the two versions is the firmware. I expect that the keyboard version would do what you want.
A cut down version of Geoff's ASCII Video Terminal may also do what you want - I think that's the board you are thinking of. That is described on his web site and in more detail in Silicon Chip February 2014.
Other members have ported MMBasic to the PIC32MX270 see here. You could use this to roll your own.
Posted: 10:32am 02 Apr 2019
I did a tidy up of the H7 code and the F7 variant and put a lot of conditional compilation in so that as much of the source as possible could be common. This means that I have done an update to the F7 despite my earlier protestations. It now has all the recent H7 functionality like polygons, turtle graphics, etc.
2019-04-02_202937_ArmmiteF7.zip
Use the H7 manual for details:
2019-04-02_203055_Armmite_H7_Manual.pdf
Differences as before:
Posted: 12:53pm 29 Apr 2019
Version that includes MP3 playback, LIST COMMANDS, LIST FUNCTIONS, MM.INFO$(), DO/LOOP bug fix as per Armmite H7
2019-04-30_030735_ArmmiteF7.zip
Edited by matherp 2019-05-01
