Local Time 14:55 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Saving Data to RTC
palcal
Posted: 12:53am 01 Feb 2019
I started a new thread for this.
So I have played around with Grogsters code and came up with..
SUB SAVETORTC
Local X 'A local X variable, perhaps totally seperate from a global X
For X=1 to 3 'Step through the three-byte date data, and save it to the RTC RAM
RTC SETREG 50+X, MID$(R$,X,1) 'Put data into RTC register R$ is numeric
Next
END SUB
SUB READRTC
R_Save$=""
Local X,BYTE
For X=1 to 3
RTC GETREG 50+X,BYTE
R_Save$=R_Save$+CHR$(BYTE) ' use "Rain_Saved = Val(R_Save$)" to get value
Next
END SUB
it runs without error but does not work, whether it is not writing or not reading I don't know or maybe both.
palcal
Posted: 12:55am 01 Feb 2019
Think I found a mistake....
OOPS WRONG THINKING THERE
cancel that.
Edited by palcal 2019-02-02
Posted: 02:43am 01 Feb 2019
I don't have a RTC with ram but you are trying to save a character when it should be a number
I have converted your SUBs to FUNCTIONs and added ASC(MID$(R$,X,1))
  Quote   rain$ = "456"
x = SAVETORTC(rain$)
oldrain$ = READRTC$()
PRINT oldrain$
FUNCTION SAVETORTC(R$)
LOCAL X 'A local X variable, perhaps totally seperate from a global X
FOR X=1 TO 3 'Step through the three-byte date data, and save it to the RTC RAM
RTC SETREG 50+X, ASC(MID$(R$,X,1)) 'Put data into RTC register R$ is numeric
NEXT
END FUNCTION
FUNCTION READRTC$()
LOCAL X,B, R$
FOR X=1 TO 3
RTC GETREG 50+X,B
R$=R$+
CHR$(B) ' use "Rain_Saved = Val(R_Save$)" to get value
NEXT
READRTC$ = R$
END FUNCTION
I have used RETREG and GETREG to configure clock options without any issues.
