Local Time 14:55 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Counting Problem
palcal
Posted: 11:37pm 29 Jan 2019
I am using a counting input and saving the variable using VAR SAVE in case of a power loss. My problem is the counter starts from zero, how do I get the counter to start from the last known value.
VAR RESTORE
Setpin 15,CIN
x = Pin(15)
Var Save x
Loop
So I RESTORE x but in the line 'x=Pin(15)' x returns to zero because the counter resets after the power cut.
Posted: 12:09am 30 Jan 2019
  Quote   VAR RESTORE
backup = x
' retrieve the saved count
SETPIN 15,CIN
DO
x =
PIN(15) + backup
VAR SAVE x
LOOP
palcal
Posted: 12:28am 30 Jan 2019
@ Tassie Jim
I tried that but @#%$!#@$ oops I think I did it wrong.Edited by palcal 2019-01-31
palcal
Posted: 12:41am 30 Jan 2019
Thanks Jim it's working OK.
Posted: 01:26am 30 Jan 2019
Hey - Won't the above code wear out the Flash memory very quickly?
My understanding is that there is a finite number of 'write' cycles, and the above Do/Loop will hit this limit in no time. Once reached, the returned data is not guaranteed.
I may be wrong, so maybe someone else can confirm . . .Edited by WhiteWizzard 2019-01-31
Posted: 01:33am 30 Jan 2019
I think it only writes if the variable value has changed so it depends on how fast it's counting.
If it's my rain gauge, you wouldn't have a problem at the moment.
palcal
Posted: 04:04am 30 Jan 2019
Well it is my rain gauge and WW brings up a good point. We had 150mm yesterday and so far today(5hrs) we have had another 75mm. I may have to find another way of doing it.
edit. My Do/Loop is not so quick at the moment it is set at 10 minutes.Edited by palcal 2019-01-31
palcal
Posted: 04:35am 30 Jan 2019
Looks like I may be able to use RTC SETREG and RTC GETREG. But according to the manual the format is 'RTC SETREG reg,value' and I don't know if I can use a variable for value I will experiment. Watch this space because I'm sure I will need help.
Edit....Well I tried and like I thought had no idea the memory starts at address 20 decimal
Edit again.... Just found something from good old dependable Grogster (well maybe not so old) in my post about HC-12's. Will try his code when I can get back out to my workshop, it's a bit wet, we have had 450mm. of rain since Sunday.Edited by palcal 2019-01-31
palcal
Posted: 06:40am 30 Jan 2019
OK Tried Grogs code
SUB SAVETORTC(DTA$)
Local X 'A local X variable, perhaps totally seperate from a global X
For X=1 to 3 'Step through the three-byte date data, and save it to the RTC RAM
RTC SETREG 50+X,ASC(MID$(DTA$(X,1)) 'Put data into RTC register
Next
END SUB
and after adding a missing closing bracket I get an ARGUMENT COUNT error on line 4 and can't see why.
Posted: 07:00am 30 Jan 2019
  Quote  RTC SETREG 50+X,ASC(MID$(DTA$,X,1))
You had a bracket after DTA$ instead of a comma.
450mm seems a bit greedy.
We have fires everywhere and could really do with some if you can spare it.
Posted: 07:09am 30 Jan 2019
@palcal
I recently needed to store three bytes (values between 0 and 255) and was using VAR SAVE and VAR RESTORE along with OPTION AUTORUN ON. This was on v5.05.01 and I ran into issues as mentioned in another recent theead (I.e. the values were not always restored correctly on power-up) Removing AUTORUN and it worked every time.
So I ended up using three RTC registers (those for Alarm2) and everything worked much better, but there was still the occasional load error on startup (as in the variables were left empty as opposed to being loaded with the stored values).
In the mix, I am also using an OLED driver which loads on start-up BUT to date I have not found a repeatable sequence of events to give Geoff and Peter anything to work with.
Anyway, the RTC registers method will work but you still want to minimise write cycles wherever possible.
Will be keen to hear how you get on. IF you have weird issues, do post your OPTION LIST, and mm.ver
WW
Posted: 08:40am 30 Jan 2019
  Quote   My problem is the counter starts from zero, how do I get the counter to start from the last known value.
On some of my versions (can't remember which) I've implemented
PIN(COUNTpin)=initvalue
I think this is generally useful and perhaps something Geoff could adopt.
palcal
Posted: 09:02am 30 Jan 2019
@ Matherp... I agree.
Ok The save now works or at least it runs but a problem retrieving the data
Grogs code
FUNCTION READRTC(DTA$)
Local D$,X,BYTE
For X=1 to 3
RTC GETREG 50+X,BYTE
DTA$=DTA$+CHR$(BYTE)
Next
END FUNCTION
When I use READRTC(DTA$) I get an error 'UNKNOWN COMMAND'
Posted: 07:31pm 30 Jan 2019
The original code is a SUB, you have made it a FUNCTION.
palcal
Posted: 11:53pm 30 Jan 2019
I copy and pasted that, I thought it should maybe a sub.
Grogs just jotted the code out and warned me it was untested. So no fault of his.
When I get it running I will put it in the library.
Posted: 06:27am 31 Jan 2019
Hello.
Glad to see you are playing with this idea some more. No, I never tested the code, I just wrote what I thought would work, but as an untested code, it at least gives you a starting point.
Try: VALUE$=READRTC(DTA$)
This SHOULD return the data bytes generated by the read in the function in DTA$, to string VALUE$. IE: VALUE$ should now represent the data you requested from the RTC memory.
AGAIN - Untested, but it might give you something to play with.
EDIT: ....and I might have totally mucked up my functions and subs. I am not very good with functions!
I probably should have written it as a sub! (still can if you want)
Edited by Grogster 2019-02-01
palcal
Posted: 11:32pm 31 Jan 2019
So I have played around with Grogsters code and came up with..
SUB SAVETORTC
RTC SETREG 50+X, MID$(R$,X,1) 'Put data into RTC register R$ is numeric
Next
END SUB
SUB READRTC
R_Save$=""
Local X,BYTE
For X=1 to 3
R_Save$=R_Save$+CHR$(BYTE) ' use "Rain_Saved = Val(R_Save$)" to get value
Next
END SUB
it runs without error but does not work, whether it is not writing or not reading I don't know or maybe both.
Edited by palcal 2019-02-02
