Local Time 13:54 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Anyone with a Pi Zero W?
lew247
Posted: 12:30pm 25 Jan 2019
Has anyone got a Pi Zero W (running Picromite) and is willing to test a program for me?
It's not complete and it's working but with a slight error I cannot find
When I run the program the first time it does the first step in the program and stops
If I run it a second time it runs normally and works fine
I can't figure out why
If you can test for me and see if you can spot why let me know and I'll send you the code
Posted: 01:21pm 25 Jan 2019
Hi Lewis,
email me the code and I should be able to take a look later . . .
Posted: 01:54pm 25 Jan 2019
Or post the code, if you're willing, and anyone can take a look. I think the pi-cromite on the Pi Zero W is a great platform.
lew247
Sent, can you let me know if it arrives as I didn't zip it up and I'm not certain if Gmail classes .bas files as ok
