Local Time 13:54 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Weird MMEdit problem
BrianP
Posted: 02:14am 22 Jan 2019
Hi all
HELP!
Has anyone experienced a similar issue with file operations in MMEdit (win 10)?
(Please don't tell me to ditch Windows!)
Currently running the latest version (3.7.5) which WAS working perfectly. I had occasion to uninstall / reinstall, after which any attempt to access the file system (open or save) results in this error - "Error 0 String can't hold String".
Have tried all the usuals - reboot, reinstall, install earlier version (3.7.0 & 3.6), stood on my head for 10mins, etc. etc. - still the same issue.
I can paste from notepad into MMEdit & use it normally, just can't save (but saving syntax changes works - currently using Maximite_V4.5). So, I have to re-paste back into Notepad to save.
All other Windows file operations in other programs work fine, it's only MMEdit! (Jim I think Bill heard you swearing at him...).
Obviously I have done something wrong somewhere, but all I did was uninstall / reinstall MMEdit!
Too many bruises from head-banging now - any thoughts or ideas will be extremely welcome...
Brian P.
Posted: 02:20am 22 Jan 2019
I suspect a corrupted configuration file.
Uninstall then delete the data folder.
In my case it is in:
Data folder: C:\Users\Jim\AppData\Local\CCom\MMedit
BrianP
Posted: 04:12am 22 Jan 2019
Thanx Jim - I had already been there - no change. I'll go through the motions again though.
B
Posted: 04:16am 22 Jan 2019
If the program starts, it has already read a number of files so it can open some files.
Perhaps your AV is not happy with something.
BrianP
Posted: 04:33am 22 Jan 2019
Done again Jim - uninstalled, deleted Ccom from appdata folder, reinstalled version 3.7.0. Same issue.
B
BrianP
Posted: 04:35am 22 Jan 2019
PS -AV disabled - same issue.
B
Posted: 04:40am 22 Jan 2019
In that case I guess that it doesn't like one of the initial settings.
Can you post a copy of the configuration report. (or send it via PM if you prefer.
You're lucky it's too hot here to work outside today.
Trevorc
Posted: 09:30am 22 Jan 2019
Just a thought,I have had a similar problem with some midi music software.
I solved it by running it as administrator. Works OK now.
Trevorc
BrianP
Posted: 09:48am 22 Jan 2019
Jim - PM sent...
B
BrianP
Posted: 10:06am 22 Jan 2019
@Trevorc - had tried that too...
Posted: 11:05am 22 Jan 2019
  TassyJim said  You're lucky it's too hot here to work outside today.
You must be kidding. 30 max in Burnie. That is just perfect.
BrianP
Posted: 01:06am 23 Jan 2019
Problem fixed!
Jim has nailed the issue (PM sent Jim) & all is now working. It seems MMEdit didn't like using a network path.
My NAS drive was in fact already mapped to drive Y: but Windows returns the network path, not the drive letter, when asked (my documents path is changed to the NAS, not local).
What must have happened with the reinstall was that we got the network path, not the original drive mapping. What fixes it is to change the entries in locate.inf to use the drive letter & magic! - it now works.
Thanks all for your help.
B
Posted: 03:33am 23 Jan 2019
To give a little more information.
It is a 'feature' of Liberty Basic.
MMEdit can use network paths but the 'file save' dialog doesn't like network paths as the default/starting directory.
During installation, when MMEdit asked Windows where the MyDocuments folder was, Windows gave a network path so all attempts to open or save failed miserably.
I will trap a MyDocuments network drive problem in the next update.
Posted: 05:08am 23 Jan 2019
Brian,
Could you run the attached program and sent me the results.
I am curious to see what Windows returns for the various folders on your system
The results get copied to the clipboard.
2019-01-23_150648_folders.zip
My results are:
APPDATA C:\Users\Jim\AppData\Roaming\
PROFILE C:\Users\Jim\
PERSONAL C:\Users\Jim\Documents\
I am looking for a default for when the Documents folder fails.
