Local Time 10:57 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite eXtreme: V5.05.01
Posted: 11:12am 29 Nov 2018
Please find attached version V5.05.01 of the Micromite eXtreme (MMX) firmware.
For the 100/144 pin parts:
2018-11-29_212107_MMX5.05.01.zip
and for the 64-pin parts:
2018-11-29_212157_MMX645.05.01.zip
updated manual:
2018-11-29_210840_Micromite_eXtreme_Manual.pdf
This brings the numbering back in line with the MM2/MM+
The code contains the new GUI controls and the various bug fixes that Geoff has included in 5.05.01.
It includes a new function and command MM.PERSIST. MM.PERSIST is an integer variable that is not affected by CPU RESTART or a watchdog restart. So you can assign a value to it.
MM.PERSIST=123
then restart
CPU RESTART
then use the variable
? MM.PERSIST
In addition it includes 2 new functions copied from the Armmite L4 which make date and time arithmetic much easier
DATETIME$(n)
Returns the date and time corresponding to the epoch number n (number of seconds that have elapsed since midnight GMT on January 1, 1970). The format of the returned string is “dd-mm-yyyy hh:mm:ss”. Use the text NOW to get the current datetime string, i.e. a$ = DATETIME$(NOW)
EPOCH(DATETIME$)
Returns the the epoch number (number of seconds that have elapsed since midnight GMT on January 1, 1970) for the supplied DATETIME$ string. The format for DATETIME$ is “dd-mm-yyyy hh:mm:ss”. Use NOW to get the epoch number for the current date and time, i.e. n% = EPOCH(NOW)
an example of use to, for example, wait until midnight (00:00 tomorrow) irrespective of month and year changes and without needing any sort of calendar would be:
n%=EPOCH(NOW)+86400 'get an epoch number for a time we know is tomorrow
t$=left$(datetime$(n%),11)+"00:00:00" 'create a time string for midnight
m%=EPOCH(t$) 'calculate the epoch number for midnight
do
loop while EPOCH(NOW) <= m% 'loop until we are at or past midnight
Edited by matherp 2018-11-30
PicFan
Posted: 08:53pm 29 Nov 2018
Hi Peter !
Many thanks and best regards from Austria !
Wolfgang
cdeagle
Posted: 09:21pm 29 Nov 2018
Thanks Peter.
circuit
Posted: 09:27am 28 Jun 2022
  matherp said  Please find attached version V5.05.01 of the Micromite eXtreme (MMX) firmware.
updated manual:
MM.PERSIST=123
then restart
CPU RESTART
? MM.PERSIST
<edited><editID>matherp</editID><editDate>43433.8903009259</editDate></edited>
Peter,
When I set MM.PERSIST = 123 it is accepted.
Print MM.PERSIST returns 123.  But when I reboot the value is back at zero.
What might I be doing incorrectly?
The chip is PIC32MZ20048EFH144-250/IPL and the firmware is v 5.05.04.
It is a bit challenging searching back on the site for specific firmware; Geoff's site still points to V5.04.08 as the current firmware.  Am I correct in thinking 5.05.04 is, in fact, the current firmware for this chip? Anything further on the horizon?
Posted: 10:03am 28 Jun 2022
  Quote  What might I be doing incorrectly?
I suspect I removed it to save a command slot and mm.persist is just being treated as a normal variable.
  Quote  Anything further on the horizon?
I have done a beta with a lot of the CMM2 performance enhancements but as the chips are pretty much unavailable at the moment haven't looked at it for ages. I would recommend sticking with 5.05.04 and putting up with any bugs/limitations
