Local Time 13:22 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Using the Pi-cromite for projects
MikeO
Posted: 05:51am 17 Nov 2018
I mentioned in a recent post here , for my home weather station, that I had originally fully intended to use a Model Pi3B as the main controller but had run into so many reliability problems that I eventually used a MX470 instead, just so I could just get then project working and completed, Well working it is and rock solid with weather live data now being displayed here and also collected on my thingspeak channel .
However since I finished this project it has been nagging me that the original plan to use a Pi was not successful and so problematic, especially seeing Peter has put so much time into it and is so responsive to requests for changes, bugs, and features.
So I started looking at it again, I wanted to share here the problems I was having and what diagnostic tests I had done. I will say I find the Pi does present extra layers / hurdles which I am not totally confident in handling compared to a standard micromite which is another reason in raising this here, I would like to know what other contributors experiences have been, what kind of coding/projects they have tried, successful? or not, how they tackle fault finding, Etc.
My experience outlined in the post above, was to use the Pi as a data processor with 3 main tasks. 1. Receiving (via WiFi UDP protocol) data from the wind sensor (speed and direction) 2. Read some local sensors (Temp, Rain, Pres, Hum), 3. finally collate all this data and send it to: Local network (UDP) and Thinkspeak channel. Quite a lot going on but it all worked well for an hour or so but then crashed and the Pi had to be power reset, very frustrating.
I didn’t try many things I was a bit lost in fact, I had quite a few print statements in my code , my gut feeling was saying I should remove them or some at least and perhaps could have pulsed some digital outputs and viewed on a scope but I didn’t take that step. From memory it was pretty well the same code ( except the additional ESP8266 interface code) that was used on the MX470 so I don’t think the problem was the code pur se. The code is below.
My tests again in past few days, used a very simple test routine , just receiving some UDP messages and every minute or so requesting som weather data from Weather Underground. I have a couple of model Pi3 boards so to rule out any hardware I used the second board and i also created a completely fresh SD card. This code also crashes after running around 1-2 hrs. Again my inclination is to remove print statements but I have not done this as yet as I was keen first to get some input or particularly other forum members experiences.
Mike
Simple recent code
dim integer a(1000)
dim l%
on error skip
udp close
pause 1000
udp server 5001
l%=l%+1
UDP receive a1$,b$,c%
'Text 0,0,a1$
print a1$,b$,c%
Pause 1000
if l%>60 then
system "curl http://api.wunderground.com/api/1efa4dd621424929/conditions/q/AU/Melbourne.json -m 60",a()
for i=1 to llen(a())
print lgetstr$(a(),i,1);
next i
l%=0
end if
loop
Original weather station code
'Michael Ogden Oct 2018
'Credits
'RPI Weather Station
'Change Log
'ver 0.05 beta
'ver 0.06b
'add in Wifi support Lib 3.76
option explicit
option autorun on
'OPTION SDCARD 49
if mm.watchdog then Print "Reset error"
'cpu 48
sub MM.STARTUP
'set Nowifi=1 if no ESP8266
'Nowifi=1
end sub
'BME280 routines and test harness
const BME280_ADDRESS = &H77
const BME280_REGISTER_T1 = &H88
const BME280_REGISTER_P1 = &H8E
const BME280_REGISTER_H1 = &HA1
const BME280_REGISTER_H2 = &HE1
const BME280_REGISTER_CHIPID = &HD0
const BME280_REGISTER_CONTROLHUMID = &HF2
const BME280_REGISTER_CONTROL = &HF4
const BME280_REGISTER_PRESSUREDATA = &HF7
const BME280_REGISTER_TEMPDATA = &HFA
const BME280_REGISTER_HUMIDDATA = &HFD
dim integer s16=&HFFFFFFFFFFFF0000 , s16b=&H8000
dim integer s12=&HFFFFFFFFFFFFF000 , s12b=&H800
dim integer s8= &HFFFFFFFFFFFFFF00 , s8b=&H80
DIM INTEGER T1,T2,T3 'uint16_t, int16_t, int16_t
DIM INTEGER P1,P2,P3,P4,P5,P6,P7,P8,P9 'uint16_t, 8 x int16_t
DIM INTEGER H1,H2,H3,H4,H5,H6 'uint8_t, int16_t , uint8_t, int16_t, int16_t, int8_t
dim INTEGER t_fine 'used to store accurate temp reading from temp conversion for use in pressure and humidity conversions
'end bme280 setup
' general Variables
dim string api_key$="9TQZQVPQKCSKZS50"
dim string m$="api.thingspeak.com/update?api_key="+api_key$+"&field1="
'dim wow$="192.168.0.116/template/data/update.php?"
dim wow$="codenquilts.com.au/template/data/update?"
dim string a1,b$,send$
dim Integer c,rainclk,secs
dim Float otemp,pres,hum,rain,caseTemp
'Dim Flag(20) def in Library
'Flags
'1=Thinkspeak upload
'2=Wunderground upload
'3=rain
'I/O
SETPIN 11,INTl,rain_click,pullup' triggers on a Low
setpin 29,dout,,pullup
settick 1000,tick,1
'setpin 14, dout
pin(29)=0 'Red Led
'Constants
const node$="ESP_Weather"
const serv$="ESP_Svr"
'Var
dim integer a(1000)
dim l%
'Initialise
bme280_init 'initialise bme280
on error skip
'udp server 5001 'initialise UDP server
TEMPR START 13,3 'initialise temp
pause 100
'main loop
'***** mxWiFi Hook **** Network only
if userprocessflag=1 then
'StartTime = Timer
UserProcess
UserProcessFlag=0
xbsend "udp.send:|"+from$+"|"+chr$(4)+"|"
'Print "Processing elapsed time"; Timer-StartTime
watchdog 10000
continue do 'skip to a new loop immediately , there may be more external processing to do
endif
'***** End mxWiFi Hook ****
watchdog 10000
if get_udp()>0 then print a1$
if flag(3)=1 then
rain=rainclk
otemp=read_temp()
casetemp=bme280_read_temp()
pres=bme280_read_pressure()
hum=bme280_read_humidity()
print "Rain:" + str$(rain)
print "Temperature:" +str$(otemp,2,1)
print "bme280_Temp:" +str$(casetemp,2,1)
print "Pressure:" +str$(pres,4,1)
print "Humidity:" +str$(hum,2,1)
print "Wind Speed:";str$(wspeed)
print "Wind Dir:";str$(wdir)
print
send$="&node=Weather&f1="+str$(otemp,2,1)+"&f2="+str$(hum,2,1)+"&f3="+str$(pres,4,1)
send$=send$+"&f4="+str$(wspeed)+"&f5="+str$(wspeed)+"&f6="+str$(rain)+"&f7="+str$(rain)
send$=send$+"&f8="+str$(wdir)
'send$=str$(otemp,2,1)+","+str$(hum,2,1)+","+str$(pres,4,1)+","+str$(wspeed)+","+str$(wspeed)
'send$=send$+send$+","+str$(rain)+","+str$(rain)+","+str$(wdir)
'UDP Network only transmission,data may be sent by other means
xbsend "udp.cast:"+send$
WaitforReady 'reset flag
'xbsend "ts.send:"+tskey$+":"+str$(3)+":"+str$(wspeed)+":"
' WaitforReady 'reset flag
send$=m$+str$(otemp,2,1)+"&field2="+str$(hum,2,1)+"&field3="+str$(wspeed)+"&field4="+str$(wdir)
send$=send$+"&field5="+str$(pres,4,1)+"&field6="+str$(rain)
xbsend "netsend:"+send$
print send$
flag(3)=0
pause 1000
end if
' if flag(4)=1 then
' send$="&f1="+str$(otemp,2,1)+"&f2="+str$(hum,2,1)+"&f3="+str$(pres,4,1)
' send$=send$+"&f4="+str$(wspeed)+"&f5="+str$(wspeed)+"&f6="+str$(rain)+"&f7="+str$(rain)
' send$=send$+"&f8="+str$(wdir)
' xbsend "netsend:"+send$
' print send$
' flag(4)=0
' pause 1000
' end if
loop
' Subs and functions
'rain interupt
sub rain_click
rainclk=rainclk+1
pause 500
end sub
'one second interupt
sub tick
secs=secs+1
pulse 29,50 'Red led
if secs mod 15 = 0 then flag(3)=1 'set sensor flag
if secs mod 30 = 0 then flag(4)=1 'set sensor flag
end sub
'read UDP port
function get_udp() as integer
'UDP receive a1,b,c
get_udp=c
end function
function read_temp() as float
read_temp=1000
on error skip
read_temp=tempr(13)
end function
function bme280_read_temp() as float
local integer var1,var2,adc_T
local adc%(2)
i2c write BME280_ADDRESS,1,1,BME280_REGISTER_TEMPDATA
i2c read BME280_ADDRESS,0,3,adc%()
adc_T=((adc%(0)<<16) OR (adc%(1)<<8) or adc%(2))>>4
var1 = ((((adc_T>>3) - (T1 <<1))) * T2) \ q(11)
var2 = (((((adc_T>>4) - (T1)) * ((adc_T\ q(4)) - (T1))) \ q(12)) * (T3)) \ q(14)
t_fine = var1 + var2
bme280_read_temp = ((t_fine * 5 + 128) \ q(8))/100.0
end function
function bme280_read_pressure() as float
local integer var1, var2, adc_P, p
local adc%(2)
i2c write BME280_ADDRESS,1,1,BME280_REGISTER_PRESSUREDATA
adc_P=((adc%(0)<<16) OR (adc%(1)<<8) or adc%(2))>>4
var1 = t_fine - 128000
var2 = var1 * var1 * P6
var2 = var2 + ((var1 * P5)<<17)
var2 = var2 + (P4 << 35)
var1 = ((var1 * var1 * P3)\ q(8)) + ((var1 * P2)<<12)
var1 = ((1<<47)+var1)*P1\ q(33)
if var1 = 0 THEN
bme280_read_pressure = 0' avoid exception caused by division by zero
exit function
endif
p = 1048576 - adc_P
p = (((p<<31) - var2)*3125) \ var1
var1 = (P9 * (p\ q(13)) * (p\ q(13))) \ q(25)
var2 = (P8 * p) \ q(19)
p = ((p + var1 + var2) \ q(8)) + (P7<<4)
bme280_read_pressure = p/25600.0
end function
function bme280_read_humidity() as float
local integer v_x1,adc_H
local adc%(1)
i2c write BME280_ADDRESS,1,1,BME280_REGISTER_HUMIDDATA
i2c read BME280_ADDRESS,0,2,adc%()
adc_H=(adc%(0)<<8) or adc%(1)
v_x1 = t_fine - 76800
v_x1=(((((adc_H<<14)-((H4)<<20)-(H5*v_x1))+16384)\ q(15))*(((((((v_x1*H6)\ q(10))*(((v_x1*H3)\ q(11))+32768))\ q(10))+2097152)*H2+8192)\ q(14)))
v_x1 = (v_x1 - (((((v_x1 \ q(15)) * (v_x1 \ q(15))) \ q(7)) * (H1)) \ q(4)))
if v_x1< 0 then v_x1 = 0
if v_x1 > 419430400 then v_x1= 419430400
bme280_read_humidity = (v_x1\ q(12)) / 1024.0
end function
sub bme280_init
local i%,cal%(17)
i2c open 400,1000 '400KHz bus speed
i2c write BME280_ADDRESS,1,1,BME280_REGISTER_CHIPID
i2c read BME280_ADDRESS,0,1,i%
if i%<>&H60 then print "Error BME280 not found"
i2c write BME280_ADDRESS,1,1,BME280_REGISTER_T1
i2c read BME280_ADDRESS,0,6,cal%()
T1=cal%(0) OR (cal%(1)<< 8)
T2=cal%(2) OR (cal%(3)<< 8): if T2 and s16b then T2=T2 OR s16 'sign extend if required
T3=cal%(4) OR (cal%(5)<< 8): if T3 and s16b then T3=T3 OR s16
i2c write BME280_ADDRESS,1,1,BME280_REGISTER_P1
i2c read BME280_ADDRESS,0,18,cal%()
P1=cal%(0) OR (cal%(1)<<8)
P2=cal%(2) OR (cal%(3)<<8): if P2 and s16b then P2=P2 OR s16 'sign extend if required
P3=cal%(4) OR (cal%(5)<<8): if P3 and s16b then P3=P3 OR s16
P4=cal%(6) OR (cal%(7)<<8): if P4 and s16b then P4=P4 OR s16
P5=cal%(8) OR (cal%(9)<<8): if P5 and s16b then P5=P5 OR s16
P6=cal%(10) OR (cal%(11)<<8): if P6 and s16b then P6=P6 OR s16
P7=cal%(12) OR (cal%(13)<<8): if P7 and s16b then P7=P7 OR s16
P8=cal%(14) OR (cal%(15)<<8): if P8 and s16b then P8=P8 OR s16
P9=cal%(16) OR (cal%(17)<<8): if P9 and s16b then P9=P9 OR s16
i2c write BME280_ADDRESS,1,1,BME280_REGISTER_H1
i2c read BME280_ADDRESS,0,1,H1
i2c write BME280_ADDRESS,1,1,BME280_REGISTER_H2
i2c read BME280_ADDRESS,0,7,cal%()
H2=cal%(0) OR (cal%(1)<< 8): if H2 and s16b then H2=H2 OR s16 'sign extend if required
H3=cal%(2)
H6=cal%(6): if H6 and s8b then H6=H6 OR s8 'sign extend if required
H4=(cal%(3)<<4) OR (cal%(4) and &H0F): if H4 and s12b then H4=H4 OR s12 'sign extend if required
H5=(cal%(5)<<4) OR (cal%(4)>>4): if H5 and s12b then H5=H5 OR s12
i2c write BME280_ADDRESS,0,2,BME280_REGISTER_CONTROLHUMID,&H05 '16x oversampling humidity
i2c write BME280_ADDRESS,0,2,BME280_REGISTER_CONTROL,&HB7 '16x oversampling pressure/temp, normal mode
end sub
function q(x as integer) as integer 'returns 2 raised to the power
q=(1<<x)
End Function
'External command processing sub Routine if required, network only
sub extCmd
local st$
'print "External Commands:";from$;",";cmd$;",";cfg$;",",strin$
if cmd$="ESP_Wind" then
st$=strin$
print "Wind:";st$
wdir=val(parse$(st$,1,","))
wspeed=val(parse$(st$,4,","))
end if
end Sub
'format: YYYY-mm-DD HH:mm:ss, where ':' is encoded as %3A,
'and the space is encoded as either '+' or %20. An example,
'valid date would be: 2011-02-29+10%3A32%3A55,
'for the 2nd of Feb, 2011 at 10:32:55.
'Note that the time is in 24 hour format.
'Also note that the date must be adjusted to UTC time -
'equivalent to the GMT time zone..
'This is especially important for users outside the UK
function dateutc() as string
local string hh,min,ss,dd,mm,yy
yy=right$(date$,4)
mm=mid$(date$,4,2)
dd=left$(date$,2)
hh=left$(time$,2)
min=mid$(time$,4,2)
ss=right$(time$,2)
dateutc=yy+"-"+mm+"-"+dd+"+"+hh+"%3A"+min+"%3A"+ss
end function
Codenquilts
disco4now
Posted: 06:49am 17 Nov 2018
Hi Mike,
I have a weather station based on Pi3. It gets data via darksky api.
I use a SYSTEM call to WGET to get the data and JSON to parse it.
With latest MMbasic seems to run pretty reliably(days/weeks). (previous memory leaks in JSON command and calling SUB with a string now fixed)
I use
'screen - provides terminal for current session so you can close putty.
'screen -D -r - lists screen sessions you can reconnect to
to run it without the connected terminal. If it dies you can reconnected to see what happened. On another session look at what linux processes are running to get some clues.
WGET is blocking so if it doesn't return it can stop. I have yet to try it with CURL as you previously suggested.
I have a LCD screen attached so put some debug info on there, I don't print continually during each loop.
I trouble shoot this type of thing by taking bits out until it no longer stops, then put them back until I find the culprit.
How do your failures present,
a) freeze - no response
b) return to MMBasic prompt
c) return to linux prompt
d) what processes are running e.g. MMbasic, CURL
How to you keep the MMBasic session alive.
a) permanent connected terminal
b) screen
c) other.
You could repeat this bit of code say 5 times in a row in your code and see if
it affects the amount of time it will run to see it print is having an effect.
next i
regards
Gerry
Edited by disco4now 2018-11-18
F4 H7FotSF4xGT
MikeO
Posted: 09:22am 17 Nov 2018
Hi Gerry, thanks for your comments. I admit I am not totally confident with Linux but am aware of screen so will give that a go again. During the last tests I have been using the com port via the option console command. My failures I believe have all resulted in the Pi being frozen (even when I was using a session) so no possibility of logging in again anyway.
As mentioned my gut feeling was to remove prints and see the result, so I must do that.
Thanks again for your suggestions.
Mike
Codenquilts
Posted: 09:40am 17 Nov 2018
Mike
Do you have an LCD connected? What power supply are you using - Pis are very sensitive to poor power? Is it overheating - MMBasic runs at 100% on one CPU? Which version of the Pi? Raspbian Lite or full? Stretch or Jessie? Are you using the serial console or an SSH console?
I'm running your test program with another Pi-cromite sending UDP messages every 1.5 seconds. At 1 hour so far and still OK.
UPDATE 2 hours and all OK running Jessie Raspbian Lite on Pi-Zero, serial console on com 1. The UDP sender is Full Raspbian Stretch on Pi3, MMBasic on SSH terminal.
UPDATE Over 3 hours - getting bored. No sign of memory usage expanding or other issues. It is critical if you are using a SSH terminal that it stays connected or you use a mechanism like "screen" so the the process sees a connection and print output has somewhere to go. Or just dump all output:
sudo ./mmbasic &>/dev/null &
then if started over SSH you will need to kill the two processes by hand:
ps - aux
sudo kill -9 PID1
sudo kill -9 PID2
UPDATE Over 7 hours - still goodEdited by matherp 2018-11-19
Paul_L
Posted: 07:50pm 17 Nov 2018
Hey Mike, I can't reach your codenquilts server from NY. All browsers time out. The temperature display from the thingspeak site indicates that you have not moved another 1000 km south. I don't understand the timeout. A ping to TBS takes about 70 ms from here.
Paul in NY
MikeO
Posted: 11:32pm 17 Nov 2018
Paul,
Looks like the Synology NAS fell over during the night around 4.20 am my time (~ midday Sat your time) It does a backup some time before that ? anyway its up again now. The Thingspeak channel should have been getting data.
Peter,
Plenty for me to check out there. Yes power supply, I will try out another, I had of course considered it but had made some measurements and under load it was delivering 5.16vdc on the Pi, hardly moved. I have only the basic Pi with a small lcd attached. 5v supply was rated at 2A.
Its not overheating, measures ~42C, Running Latest Raspian Stretch full but only in SSH mode from WinSCP. This last time I was running the serial console but had started the session from ssh via WinSCP, maybe the session fell over.
Its obvious I need to set up a more strategic test. Will report back.
Codenquilts
Paul_L
Posted: 07:46am 18 Nov 2018
Hmmmm. I can now reach your weather data display which looks really great, but the link below your signature on each post still times out. I think that Synology NAS is having some persistent problems.
Paul in NY
MikeO
Posted: 10:37am 18 Nov 2018
Hi Paul, OK I checked and when I hovered over it it looked like the port number in the address may be missing (although it was in the signature profile ?), the full address should be http://codenquilts.synology.me:2244/cms/index.php , the port number is required as this NAS is behind my home router and my ISP blocks the use of the "HTTP" port 80(like many residential ISPs do) so I have to use another port number and re direct to port 80 in the router, otherwise it will not connect, If you wish please try again.
Mike
Codenquilts
Paul_L
Posted: 04:51pm 18 Nov 2018
Hi Mike. The link you posted, http://codenquilts.synology.me:2244/cms/index.php, is the same as what I see when I hover over the link. Neither one works, they just time out. This has been like this for months. I remember trying to access your web site a while ago and the same thing happened.
Paul in NY
Posted: 06:13pm 18 Nov 2018
The http://codenquilts.synology.me:2244/template/indexDesktop.php one works for me as does the Thingspeak one at https://thingspeak.com/channels/17394.
The 3rd, at http://codenquilts.synology.me:2244/cms/index.php
just hangs.
john
lew247
Posted: 07:53pm 22 Nov 2018
  disco4now said
I use
regards
Gerry
How do you actually use the screen command?
Is it a Linux or MM command?
I've been using the Pi Zero W headless with wireless connection so far, I've just got it working with the usb cable connected and I'm trying to get MM running so I can disconnect the cable and leave the weather station running.
disco4now
Posted: 09:20pm 22 Nov 2018
To use screen
You probably need to install it with
sudo apt-get install screen
at the linux command.
Then type
screen
before you start up MMBASIC
It will stay running once you close the terminal.
To reconnect, you type
screen -D -r
at the linux prompt when you log back in, you then reconnect to the still running
screen session.
It will get the session back regardless of whether you are on a remote or USB login and regardless of how you logged in when you initially started it.
F4 H7FotSF4xGT
MikeO
Posted: 03:20am 23 Nov 2018
I can report that the pi-cromite code has been running now for ~3 days without a hiccup, same power supply so the problem was as you suspected the session was timing out when it wanted to print. I have no prints now and running in console mode (but nothing connected) , autorun and has a small LCD showing the received data. Thanks all for you help I can now move on with any projects using Pi-cromite with more confidence.
Also my NAS seems to be accessible from the Internet OK I have tested via my Cell Phone (so outside my local wifi network) we have had a few storms this week however and our Hi speed wireless internet service does tend to suffer in bad and rainy weather, thanks for your reports anyway.
Mike
Codenquilts
Paul_L
Posted: 03:42am 23 Nov 2018
Hi Mike, still no connection.
The connection has timed out
The server at codenquilts.synology.me is taking too long to respond.
The site could be temporarily unavailable or too busy. Try again in a few moments.
Paul in NY
Posted: 05:30pm 24 Nov 2018
Thanks to disco4now and google I've finally sorted a way of running a MMBasic program fully automatically at boot on a Pi - the steps are pretty simple (once you know how ). There may be better ways but this is how I got it working. The following assumes that the mmbasic executable is in the directory /home/pi. This is the default login directory for the username "pi".
First install the application "screen" on the pi
Next create a file "start.bash" in the same directory as mmbasic. Put the following into the file
cd /home/pi
sudo ./mmbasic
Make the script executable with the command
chmod +x start.bash
Now we need to tell Raspbian to execute screen and start.bash on boot. Edit the file "/etc/rc.local" (sudo nano /etc/rc.local) and append the following line to the file
/usr/bin/sudo -u pi /usr/bin/screen -dmS screen /home/pi/start.bash
This tells the pi to run screen under the user "pi" and to execute "start.bash" under screen.
Next, we assume we want to run a specific MMBasic program so once it is developed save it as AUTORUN.BAS in the same directory as the mmbasic executable.
Run MMBasic as normal (sudo ./mmbasic) and set the autorun option
OPTION AUTORUN ON
exit mmbasic (ctrl-Z)
Finally reboot the pi (sudo shutdown -r now") and when it reboots your MMBasic program will be running - you can check this with the command "ps -aux"
To connect to your running program execute the command
screen -D -r
and the terminal will connect so you can see any output and stop the program and edit it if required.
The use of "screen" ensures that console output from MMBasic is properly handled and your program can run happily without a console connected.
I'll include this as an appendix in the next release of the Pi-cromite manual
Attached is a simple program to email me a picture from a camera on a pi-zero every hour that now runs AUTOMATICALLY
SetTick 60000,ping
takepicture
Pause 180000
Loop
Sub ping
System "ping 8.8.8.8 -c 1" ' keep the network alive
End Sub
Sub takepicture
Local fn$, a$
a$="raspistill -o "
fn$="PIC"+Right$(Date$,4)+Mid$(Date$,4,2)+Left$(Date$,2)
fn$=fn$+Left$(Time$,2)+Mid$(Time$,4,2)+".jpg"
System a$+fn$
Print "Taken picture "+fn$
a$="mpack -s "+fn$+" "+fn$+" peter@mather.host"
System a$
Print "Emailed picture "+fn$
Kill fn$
End Sub
Edited by matherp 2018-11-26
disco4now
Posted: 10:27pm 24 Nov 2018
One minor issue I have found with screen is that if you paste your code into mmbasic with putty it sometimes will miss a character when pasting if hosted under screen. (especially if a large program). You can drop out of screen from the linux prompt using
exit
and run mmbasic without it during code development if pasting the code becomes a problem during development.
F4 H7FotSF4xGT
