Local Time 16:04 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM Extreme 64 not enough memory
astro1
Posted: 06:13am 11 Nov 2018
Running the code below exits with not enough memory. Uncomment line 12 (print date$, time$) and no error. date & Time are the same from line 9. (This is a reduce version of the code being run).
MM Extreme 64, Ver 5.04.18 @ 252MHz,
OPTION CPU 252
OPTION LCDPANEL SSD1963_4, LANDSCAPE
OPTION TOUCH 12, 14
OPTION SDCARD 18,
OPTION RTC 5, 6
OPTION HEARTBEAT ON
Results when run.
11-11-2018 05:59:48
[13] UTC = GetSec(Val(Right$(Date$, 2)), Val(Mid$(Date$, 4, 2)), Val(Left$(Date$, 2)), Val(Left$(Time$, 2)), Val(Mid$(Time$, 4, 2)), Val(Right$(Time$, 2)))
Error: Not enough memory
' MMX
option explicit
option default none
Dim Integer tyear, tmth, tday, tdow, thour, tmin, tsec, tdst
Dim Integer md(12) = (0, 0, 31, 59, 90, 120, 151, 181, 212, 243, 273, 304, 334)
Dim integer UTC
cls
print date$, time$
'print date$, time$
end
Function GetSec(yr As Integer, mth As Integer, day As Integer, hr As Integer, min As Integer, sec As Integer) As Integer
GetSec = (yr - 14) * (365 * 24 * 60)
GetSec = GetSec + ((yr - 13) \ 4) * (24 * 60)
GetSec = GetSec + (md(mth) * (24 * 60))
GetSec = GetSec + ((day - 1) * (24 * 60))
GetSec = GetSec + (hr * 60)
GetSec = ((GetSec + min) * 60) + sec
If (yr - 16) Mod 4 = 0 And mth > 2 Then GetSec = GetSec + (24 * 3600)
End Function
goc30
Posted: 08:47am 11 Nov 2018
I have same problem with micromite/mx170
if you uncomment second "print" (line12): it work correctly
Posted: 11:34am 11 Nov 2018
  Quote  Running the code below exits with not enough memory.
Please ensure you are running 5.04.19
Posted: 11:45am 11 Nov 2018
There were some problems in V5.04.09 regarding "Not enough memory" errors that should have been fixed in V5.04.10 Beta 13 for the MX170 and MX470. Download the beta version from http://geoffg.net/micromite.html#Downloads
I understand that Peter avoided this particular bug in his port of MMBasic to the MM Extreme so perhaps there is a different issue there.
EDIT: Peter beat me to the answer.
GeoffEdited by Geoffg 2018-11-12
goc30
Posted: 01:06am 12 Nov 2018
I confirme: for mx170, V5.09.10 beta 10, work correctly with astro1's programm
