Local Time 16:03 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pic32mx170F512
goc30
Posted: 01:46pm 09 Nov 2018
Hi
some one has tested micromite (or micromite+) on this news chips
pic32MX170F512
there is 2 chips, one with 64pins, and other with 100pins
all of them with 512k flash mem
Chopperp
Posted: 06:36am 10 Nov 2018
Sorry goc30, not me.
ChopperP
Posted: 08:10am 10 Nov 2018
I think that you are asking has anyone tried the MM or MM+ firmware on these chips and my guess is that the answer is no and my further guess is that it would not work or provide any advantage over the recommended chips.
The Micromite firmware is tied to specific chips and their characteristics. It is not like Windows which can reconfigure itself (Windows is about 10,000 times larger than MMBasic).
goc30
Posted: 09:48am 10 Nov 2018
  Chopperp said   Sorry goc30, not me.
ok, thank
  Geoffg said   I think that you are asking has anyone tried the MM or MM+ firmware on these chips and my guess is that the answer is no and my further guess is that it would not work or provide any advantage over the recommended chips.
sorry, I speak english like an spanish cow!
You are right
but the first reading of the data sheet seems to show that these circuits are identical to the mx170f256, just more IO and more memory. After may be, it's easier to use an mx470
I will study the datasheet more seriously to see if there is an advantage to use this chip
Edited by goc30 2018-11-11
