Local Time 13:22 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite Plus Explore 100
barrow4491
Posted: 05:31am 08 Nov 2018
I have built the Explore 100 and am having issues with some commands to configure it.
GUI TEST LCD PANEL – DOES NOTHING
GUI CALIBRATE –ALSO DOES NOTHING but if I touch the screen it reports “Touch not calibrated”
The screen is a 5 inch and the backlight command works OK
Do you have any ideas?
Edited by barrow4491 2018-11-09
Posted: 06:16am 08 Nov 2018
Show us a copy of your options.
OPTION LIST
also GUI TEST LCDPANEL doesn't have a space between LCD and PANEL
barrow4491
Posted: 06:47am 08 Nov 2018
Micromite Plus MMBasic Ver 5.04.10 Beta 13
Copyright 2011-2018 Geoff Graham
> option list
OPTION COLOURCODE ON
OPTION DISPLAY 24, 66
OPTION LCDPANEL SSD1963_5A, LANDSCAPE, 48
OPTION TOUCH 1, 40, 39
OPTION SDCARD 52
OPTION LCDPANEL CONSOLE
OPTION RTC 67, 66
LCDPANEL CONSOLE - does not work either
Posted: 06:54am 08 Nov 2018
So, if you issue GUI TEST LCDPANEL and press return, do you get the demo?
If not:
OPTION LCDPANEL NOCONSOLE - disable the LCDPANEL console for now.
Connect via a USB-serial adaptor or the USB port(which version of the E100 do you have?)
Issue the same GUI TEST LCDPANEL command via the USB-serial adaptor - does it work now?
Perhaps there is some issue with GUI TEST LCDPANEL or touch testing commands, when MMBASIC is configured to use the LCD panel as the console. I would not think so, but it is best to test this idea.
I will see if I can rustle up an E100 and a 5" LCD, set them up as you have, and see if I can get the same problems.
Oh, and welcome to the forums, BTW. Edited by Grogster 2018-11-09
barrow4491
Posted: 07:21am 08 Nov 2018
Made no difference i’m afraid. Some commands (SDCARD, RTC) seem to work but anything to do with the screen appears not to. Maybe a faulty screen?
PS the backlight command does work!
JimEdited by barrow4491 2018-11-09
Posted: 07:32am 08 Nov 2018
Do you happen to have another LCD you can try?
barrow4491
Posted: 08:25am 08 Nov 2018
I have some 2.8 inch as used in the lcd backpack
Posted: 08:39pm 08 Nov 2018
No, you would need another 5" parallel interface one.
This is odd.
As you are using a PWM pin to control the backlight, that mode DOES NOT use the 1963 chip to control the backlight, it is just a pure PWM control signal, and will work on the backlight, regardless of what the 1963 controller is actually doing.Edited by Grogster 2018-11-10
Posted: 08:48pm 08 Nov 2018
have you tried the alternative driver (without the 'A')
OPTION LCDPANEL SSD1963_5, LANDSCAPE, 48
you would have to disable the original one first
OPTION LCDPANEL DISABLE
Posted: 08:55pm 08 Nov 2018
Excellent idea.
barrow4491
Posted: 10:17pm 08 Nov 2018
Thanks,
I disabled the lcd and used the option without the “A” same result no GUI test.
I have ordered a replacement panel in case
Should I move the zero ohm resistor to 1963_PWM and see if the backlight control still works?
KeepIS
Posted: 12:03am 09 Nov 2018
Maybe I'm missing something but are you seeing anything at all on the LCD screen?
barrow4491
Posted: 12:27am 09 Nov 2018
The screen is totally blank and the console,test or calibrate commands do nothing.I can vary the backlight.
regards
disco4now
Posted: 01:15am 09 Nov 2018
Make sure the 10K pulling RD on the LCDPANEL high is in place.
Pin 6 is specified after v5.3 to nominate the RD pin so that BLIT etc can work.
> option list
OPTION AUTORUN ON
OPTION LCDPANEL SSD1963_5, LANDSCAPE,, 6
OPTION TOUCH 1, 40
OPTION SDCARD 47
OPTION RTC 67, 66
F4 H7FotSF4xGT
KeepIS
Posted: 01:25am 09 Nov 2018
I thought so, the GUI commands are really meaningless 99% of the time unless you actually have some standard text displaying.
As the post above said, go back and check connections, soldering and voltage, it could be a display fault but I'd exhaust other hardware tests/faults first.
EDIT: I assume you're looking at the backlight LEDS in the PANEL to tell that the backlight can be changed when using the backlight command?
Edited by KeepIS 2018-11-10
Posted: 02:57am 09 Nov 2018
  barrow4491 said   The screen is totally blank and the console,test or calibrate commands do nothing.I can vary the backlight.Jim
The Micromite just sends commands to the LCD Panel and does not expect a response (the panel is just a receiver of data, it does not reply). This means that you can change the backlight and not receive an error... even if the panel is faulty or not connected.
barrow4491
Posted: 03:37am 09 Nov 2018
hi,
Using pin 6 for backlight did not work reverted to 48 and the backlight works and responds to the backlight command from 5% to 100%
tried the touch option_no response
sdcard option 47 did not work as i am using the micro socket on the PCB so used 52
files command read the sd card OK
You are correct, I am watching the backlight leds to gauge the panel is on
I have given the panel a good inspection for bad solder joints etc, all seems OK
KeepIS
Posted: 03:47am 09 Nov 2018
Who built the M100? I was thinking more along the lines of checking the M100 LCD socket and supply lines.
disco4now
Posted: 03:56am 09 Nov 2018
pin 6 is for the RD pin, an additional optional parameter after v5.3. There is a sneaky comma in there, the 48 is left out if you are using the PWM backlight.
Not adding the pin 6 option will not stop it working provided the 10K pullup is there, just not allow use of BLIT and transparent text which need read mode enabled.
this might be useful Edited by disco4now 2018-11-10
F4 H7FotSF4xGT
panky
Posted: 11:17am 12 Nov 2018
Jim,
Do you have access to an oscilloscope? If so, at the console, start the LCD test with GUI TEST LCDPANEL then look with the oscilloscope at all the control lines and the data lines on the LCD connector of the E100.
You should see some activity.
- pulses from zero to 3.3 volts. I had a problem just earlier today where the MM pin used for D/C was a bad solder join and the signal at the LCD connector was a very noisy 1 volt - a give away to a floating pin.
panky.
