Local Time 15:23 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 1950’s TV assembly....
Posted: 08:03am 29 Oct 2018
1950's TV Assembly
We have come a long way.
mikeb
Posted: 08:38am 29 Oct 2018
Love the test for 'microphonics' of the valves.
At least they use corks to beat them with.
noneyabussiness
Posted: 09:43am 29 Oct 2018
Wow.. very interesting. . I wonder if that much " rigious " testing is done now days??
I think it works !!
Posted: 09:07pm 29 Oct 2018
I wondered about their sort-of 'Burn-in' test of the valves(tubes). While that is fine to do with modern stuff, even the most reliable valve would surely use up some of it's expected lifespan running that test on them? I guess they had to have quality-control, but I was quite surprised that there was THAT MUCH quality control back then.
Hatrick
Posted: 12:48am 10 Jan 2019
Yes, the "burn-in" wouldn't have been too long, given the limited life of valves and picture tubes.
I recall the days of valve TVs; the warranty on Australian-made B&W TVs was 3 months. Yes, 3 months! TV insurance was a big business back then, in case something failed after the warranty ran out. And usually did.
To fix picture tubes which had dying electron emission, one could buy a small auto-transformer which fitted between the tube and the wiring socket, which cranked up the heater volts from a nominal 6.3vac to something higher in several steps; ie, as one step became ineffectual, one moved up to the next voltage step. Until the heater eventually karked it. Insurance companies were pretty evasive about replacing faulty picture tubes, which they reckoned were not dead enough. A trick I heard of was for the owner to zap the heater with 240v. This effectively made the tube very dead, and insurance was then paid out.
Gerry
BrianP
Posted: 12:15am 11 Jan 2019
One of the most noticeable points to me is the complete lack of protective clothing / breathing gear in some of those environments. A bit different nowadays
B
