Local Time 16:18 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Liquid Cooled CPU
Phil23
Posted: 10:08pm 27 Oct 2018
So I've always had a bit of a smirk at some of the gamers & their Water Cooled CPU's in their super turbo charged rigs....
But wholly sh*t, Geoff's article in November SC....
80 Xeon server racks TOTALLY immersed in tanks of dielectric fluid for heat transfer!
One thing for sure, there'd be no dust & lint accumulating on heat sinks.
Cheers.
Posted: 12:23am 28 Oct 2018
They have an amazing installation. 56 tanks each holding servers totally submerged in an oily liquid - even the 240V power supplies are completely submerged. With a total of about 8,000 Intel Xeon Phi CPUs (72 cores in each) they have a lot of computing power.
If you have not seen the article this photo of one tank will give you the idea:
The company that built this computer is called DownUnder GeoSolutions and they process seismic data for oil and gas exploration.
Edited by Geoffg 2018-10-29
Posted: 12:29am 28 Oct 2018
Yes, that article is impressive. Do you think we could make an liquid-cooled Micromite super-computer?
Oil-cooled computers are quite a common thing. Have a look on YouTube for 'Oil cooled PC', and you will get quite a few hits. The idea of having to service a motherboard that has been submerged in cooking oil is enough to make me NEVER attempt to do it that way. Water-cooling would be a better approach if you ask me!
isochronic
Posted: 01:08am 28 Oct 2018
That was a key design feature of the Cray supercomputers when they started. So much so, that when some expansion option cards were not installed, null cards with heaters were used to fill in the slots so that the circulation would not be upset !
The Crays of the time would probably be outrun by a mobile phone now (sob).
The liquid was a fluorocarbon IIRC, liquid at room temperature, nifty stuff.
Paul_L
IBM has been building water cooled mainframes since 1978. Beginning in 1982 Pan Am used a 3090-200 in our datacenter in Rockleigh NJ. (41.009, -73.932). Our old building is now used by Spectra Laboratories for medical blood testing.
IBM is currently engaged in building the Aquasar massively parallel processor with the Swiss Federal Institute of Technology, which uses a mix of IBM QS22 and HS22 and Intel Nehalem Xeon processors. It uses distilled water at 60°C for cooling which transfers heat about 6000 times more efficiently than forced air. The captured heat is easily sold for space heating and industrial processing applications. The Swiss are apparently very interested in not wasting heat.
https://www.computerweekly.com/feature/IBM-builds-water-cooled-processor-for-Zurich-supercomputer
Just something else that makes you go hmmmmmmmmmmm ....
Paul in NY
Phil23
Posted: 05:48am 28 Oct 2018
  Grogster said  Water-cooling would be a better approach if you ask me!
Well Theoretically, IF it's distilled water you should be able to drop a complete E100 in.....
Who's up to test one?
  chronic said  The liquid was a fluorocarbon IIRC, liquid at room temperature, nifty stuff.
Dry Cleaning fluid maybe?
Carbon Tet etc?
Phil.Edited by Phil23 2018-10-29
isochronic
Posted: 07:11am 29 Oct 2018
The Cray2 used "Fluorinert".
There are videos of an unfortunate rat breathing similar stuff, enough oxygen dissolves to be life sustaining, I wouldn't try it though !!!
Maybe go for the dry cleaning fluid, probably way expensive still.
Posted: 12:44pm 29 Oct 2018
I think I remember reading somewhere that in the cooling towers, they put some blue lights under the tubes just coz it looked cool. Fair enough.
Posted: 12:41pm 30 Oct 2018
Bitcoin mining in China (BitMain).
Not liquid cooled....
