Local Time 16:31 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : code OK in MMDOS 5.04.08; 5.04.09 fails
Posted: 01:27pm 20 Oct 2018
The code below, sent to me by Paul_L, runs on his PC with 5.04.08. On mine, with 5.04.09, it fails with an out of memory error.
[code]
DOS MMBasic Ver 5.04.09
Copyright 2011-2018 Geoff Graham
Program: 4K ( 0%) used 508K free (162 lines)
Variables: 8K (24%) used 23K free (124 variables)
General RAM: 4K ( 0%) used 508K free
[55] dds(Mid$(Date$,4,2)+"/"+Mid$(Date$,1,2)+"/"+Mid$(Date$,7,4)):ddc
Error: Not enough memory
[/code]
I inserted the line, "PRINT "" : memory" before the "NEXT it" line to try to see what was happening, and it ran to completion.
[code]
' DataDumpTest.bas
Option EXPLICIT
Option DEFAULT INTEGER
Option BASE 1
Dim i, j, k, L, x, y, in$, PIC, iSimRecNo, st$, it
Dim Hstg, TkTarget, FS, FSo
Dim Xok, XFAIL '@@@@
Dim MANBLR, MODE$="O", KEYSEEK$="UAW1"
Dim UtilStat, GenStat ' for DOS test only
Dim WeM, WeD, SeM, SeD
Dim WeM2, WeD2, SeM2, SeD2
Dim WINTER, oDate$, DOY, FrWgen, FrWgen2, KEYPOINTER
Dim oatStrt, tkStrt, ratio! 'slope settings
Dim oatStrt2, tkStrt2, ratio2!
Dim FGxSensors = 0, FGxUI = 0, FGxDate = 0, FGxFileSetsData = 0
' LB x181010 If MM.Device$ <> "DOS" Then PIC=1 'PL???? PIC is used in many places
' calculated values
Dim SupHt, SubCl, FrGain, TkGain, YdGain, TkBTU, YdBTU
ArrayElementPointers: '=========================================================
Const PydF=1,PtkF=2,PcpF=3,PcpR=4,PydQ=5,PtkQ=6,Pha=7,Pgr=8,Poa=9 'S(n) Z(n)
Const PydR=10,PtkR=11,PtkC=12,PxvF=13,PxvR=14,Putil=15,Pgen=16 'T!(n,?) P(n)
Const Ptmp=1,Perr=2 'T!(?,n)
Const Pwlo=1,Pwhi=2,Pslo=3,Pshi=4 'S(?,n) Z(?,n)
Const Prtc=1, Ploop=2, Pfrho=3,Ppre=4,PflSns=5, Pstab=6
Const Ppost=7, PdataSS=8, PdataDU=9 'D(n,?)
Const Pset=1,Psmn=2,Psmx=3,Pmnlo=4,Pmxhi=5,Pstat=6, PEnd=7 'D(?,n)
Const Pfc=1,Pfrr=2,Pydp=3,Pjp=4,Pahp=5,Pgas=6,Pnav=7 'O(n,?),OPS(n)
Const Ppin=1,Pnow=2,Pneed=3,Pprob=4,Pposs=5,PtOn=6 'O(?,n)
Const PtOff=7,PttOn=8,PttOff=9 'O(?,n)
DimArrays: '====================================================================
' settings temp in pins delays status out pins trips
Const kSx=9,kSy=4, kTx=16,kTy=2, kPx=17, kDx=9,kDy=7, kOx=7,kOy=9, kZx=6,kZy=4
Dim S(kSx,kSy), T!(kTx,kTy), P(kPx), D(kDx,kDy), O(kOx,kOy), Z(kZx,kZy)
Open "GEOdump.csv" For output As #2
Restore DDdata
For x=1 To 14
Read st$:Print #2,st$;
Next x
Print #2,""
memory
for it=1 to 30 ' 30
'dds(Mid$(Date$,7,4)+Mid$(Date$,4,2)+Mid$(Date$,1,2)):ddc
'dds(Mid$(Date$,4,2)+Mid$(Date$,1,2)+Mid$(Date$,7,4)):ddc
'dds(Date$):ddc
dds(Time$):ddc:dd(NOW()):dds(MODE$):ddc:dd(MANBLR,1)
dds(KEYSEEK$):ddc:dd(KEYPOINTER,2)
For i=1 To 7
DD(O(i,Pposs),1)
Next i
dd(SupHt,5)
dd(SubCl,5)
dd(FrGain,5)
dd(TkGain,5)
dd(YdGain,5)
dd(TkBTU,5)
dd(YdBTU,5)
For x=1 To kTx '16 ydF to gen
dd(T!(x,Ptmp),3,1)
Next x '16 nnn.n
For x=1 To 7 'RtcStat to PostEnd
For y=6 To 7
dd(D(x,y),7)
Next y
Next x '7 of 9
dd(FS,2)
for x=1 to kZx '6 TRydF to TRtkQ
for y=1 to kZy '4
dd(Z(x,y),1)
Next y '4
next x '6
For x=1 To kOx '7 FRCnnpp to NAVnnpp
For y=2 To 5
dd(O(x,y),1)
Next y
For y=6 To 9
dd(O(x,y),6)
Next y
Next x
Print #2
' print "" : memory
next it
Close #2
print "" : memory
End
DDdata:
Data "Date ,Time ,Timer ,M,B,SEEK,KP,F,R,Y,J,A,G,N,"
Data "supHt,subCl,FGain,TGain,YGain,TkBTU,YdBTU,"
Data " ydF, tkF, cpF, cpR, ydQ, tkQ, hall, grnd,"
Data " oat, ydR, tkR, tkC, xvF, xvR, util, gen,"
Data "RtcStat, RtcEnd,LoopStt,LoopEnd,FrHoStt,FrHoEnd,PreStat,"
Data " PreEnd,FlowStt,FlowEnd,StabStt,StabEnd,PostStt,PostEnd,"
Data "FS,TRydF,,,,TRtkF,,,,TRcpF,,,,TRcpR,,,,TRydQ,,,,TRtkQ,,,,"
Data "FRCnnpp,,,, on, off, t on, t off,"
Data "YDPnnpp,,,, on, off, t on, t off,"
Data "FRRnnpp,,,, on, off, t on, t off,"
Data " JPnnpp,,,, on, off, t on, t off,"
Data "AHPnnpp,,,, on, off, t on, t off,"
Data "GASnnpp,,,, on, off, t on, t off,"
Data "NAVnnpp,,,, on, off, t on, t off,"
Sub dd(v,m,n,c$)
If m=0 Then m=3
If n=0 Then n=0
If c$="" Then c$="0"
Print #2, Str$(v,m,n,c$)+",";
End Sub 'dd(n)
Sub dds(ss$)
Print #2, ss$;
End Sub 'dds(ss$)
Sub ddx
Print #2, "/";
End Sub 'ddx
Sub ddc
Print #2, ",";
End Sub 'ddc
Function NOW() '^seconds since 1/1/2018 using date$ dd-mm-yyyy & time$ hh:mm:ss
Local n.yr,n.mo,n.da,n.hr,n.mn,n.s,y,n.doy,n.t.da,n.t.hr,n.t.mn,n.t.s
n.yr=Val(Mid$(Date$,7,4)):n.mo=Val(Mid$(Date$,4,2)):n.da=Val(Mid$(Date$,1,2))
n.hr=Val(Mid$(Time$,1,2)):n.mn=Val(Mid$(Time$,4,2)):n.s=Val(Mid$(Time$,7,2))
For y=2018 To n.yr-1
n.doy=DoYi(y,12,31):n.t.da=n.t.da+n.doy
Next y
n.doy=DoYi(n.yr,n.mo,n.da)
n.t.da=n.t.da+n.doy
n.t.hr=(n.t.da*24)+n.hr
n.t.mn=(n.t.hr*60)+n.mn
NOW=(n.t.mn*60)+n.s
End Function 'NOW()
Function DoYi(DoYiy%,DoYim%,DoYid%)
DoYi= DoYid% + Int((DoYim%-1)*30.57+0.5)
If DoYim%>2 Then
DoYi=DoYi-1
If (DoYiy% Mod 4)>0 Then DoYi = DoYi-1 'not leap year
If (DoYiy% Mod 100)=0 Then DoYi = DoYi-1 'not leap century
If (DoYiy% Mod 400)=0 Then DoYi = DoYi+1 'leap 4th century
EndIf
End Function 'DoYi(DoYy%,DoYm%,DoYd%)
Function DoYset(DoYd$)
Local DoYsd,DoYsm,DoYsy
DoYsd=Val(Mid$(DoYd$,1,2))
DoYsm=Val(Mid$(DoYd$,4,2))
DoYsy=Val(Mid$(DoYd$,7,4))
DoYset=DoYi(DoYsy,DoYsm,DoYsd)
End Function 'DoYset(DoYsd$)
[/code]
Paul_L
Posted: 07:30pm 20 Oct 2018
Yep Lance, it runs to completion here with or without the extra print command.
Things that make you go hmmmmmm ....
Paul in NY
DOS MMBasic Ver 5.04.08
Copyright 2011-2017 Geoff Graham
> load "datadumptest.bas"
> RUN
Program: 4K ( 0%) used 508K free (161 lines)
Posted: 05:17am 26 Oct 2018
I have tracked this one down and reported the solution in this thread: https://www.thebackshed.com/forum/forum_posts.asp?TID=10720&PN=1&get=last#126794
Paul_L
Posted: 07:49am 26 Oct 2018
Brilliant work Geoff!
Paul in NY
