Local Time 16:31 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CPU exception #6 on Explore-64
Posted: 02:06am 14 Oct 2018
I have a 777-line program which, while initializing, dies with a CPU exception #6 error. This is on an Explore-64 with what I think is the latest firmware.
CPU exception #6 (bus error on ifetch) at address 0x3C203B70
Processor restarted
> print mm.ver
5.0409
> print mm.device$
Micromite Plus
It appears to be dying on a PRINT statement. If I comment out that PRINT statement, it dies on the next one. Small programs run without issue.
Here is the program, if anyone can take a look. This previously ran successfully on an E-28 and I've just begun to convert it to the E-64. Some pin numbers could be wrong, but I think it's dying before it gets to their definition or use.
2018-10-14_120622_gh.zip
disco4now
Posted: 03:16am 14 Oct 2018
I have duplicated your error with MMBasic 5.04.09
Processor restarted
It seems to initialise OK with MMbasic 5.04.08 so more invesigation required.
GerryEdited by disco4now 2018-10-15
F4 H7FotSF4xGT
Posted: 04:26am 14 Oct 2018
When you have CPU exception errors, you have to get sneaky to catch the culprit
I added a few PRINT and PAUSE statements to the readHTMLTemplate SUB
SClear htmlBuffer()
PRINT "readHTMLTemplate startx"
PAUSE 3000
FOR i = 1 TO 20
SAddStr htmlBuffer(), A(i)
PRINT "readHTMLTemplate stage "+STR$(i)
PAUSE 3000
NEXT i
OK, I started elsewhere, but that's where I ended up.
The pauses are needed to give the print buffers time to empty before the crash.
The crash occurs on the 4th call to SAddStr. I know nothing about the CSUB so that's as far as I got.
> RUN
~458 14-10-2018 15:20:15
Flash:
31K (30%) Program (802 lines)
1K ( 0%) 6 Embedded C Routines
68K (70%) Free
RAM:
32K (32%) 118 Variables
0K ( 0%) General
65K (68%) Free
DOW: 6 -- ***
DATE: 14-10-2018
TIME: 15:20:15
DS3231 temperature: 999
readHTMLTemplate stage 1
readHTMLTemplate stage 2
readHTMLTemplate stage 3
Processor restarted
There are a few extra prints in there but the last few tell us where the problem is.
I don't know if its a memory problem or something else.
Edited by TassyJim 2018-10-15
disco4now
Posted: 05:32am 14 Oct 2018
I got down to the same area. Looks like a problem with using the longstring CFunctions after 5.04.08
Once the long string builds up to a length of 881 seems to crash despite its nominal dimension.
Gerry
F4 H7FotSF4xGT
Posted: 06:08am 14 Oct 2018
Congratulations, lizby - it appears you have found a bug.
I have a 1500 line program running on 5.04.09 now, and no problems at all. I am not printing anything other then simple strings though, so the bug must be in the long string handling.
Posted: 12:17pm 14 Oct 2018
Wow. I hadn't expected this kind of response to an obscure problem with a longish program with some lingering chip-shifting issues. I went to bed wondering if it might be a problem with the CFunctions (and not even knowing if it was ok to move them from an MM chip to an MM+--E-28 to E-64).
Thanks, Jim, for the idea of PAUSE statements allowing the PRINT buffers to clear--that had confounded my notion of where the error was occurring--I'll keep that in mind.
Thanks to everyone for investigating. I'll await developments.
Edited by lizby 2018-10-15
Posted: 01:16pm 14 Oct 2018
Thanks to disco4now's hint in the 5.04.10 Beta thread ("Here is another code snippet that runs OK under 5.04.08 but fails under 5.04.09 and 5.04.10 beta 9"), I flashed 5.04.08 and have successfully gotten past the exception.
So plowing ahead with the conversion from E-28 to E-64, with some changes.
Posted: 05:04am 26 Oct 2018
I have tracked down this bug and reported the solution in this thread: https://www.thebackshed.com/forum/forum_posts.asp?TID=10720&PN=1&get=last#126794
Posted: 02:16pm 26 Oct 2018
Thank you, Geoff. Long string CFunctions using integers rather than floats tested successfully on the E-64 with V5.04.08. I'll await the next 5.04.10 release rather than re-flashing 5.04.09.
