Local Time 16:45 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : "Control-C -> Continue" problem
rentner111
Posted: 06:36pm 02 Oct 2018
The "CONTINUE" command after a "Contol-C" in the chat window is a very useful command for debugging programs.
Unfortunately, it is only very limited to use.
Up to version V5.2, the "CONTINUE" command still worked correctly after a "Contol-C".
The following small program demonstrates the problem that only starts with version V5.3.
Unfortunately, "continue" does not work correctly even with the newer MM, MM + and MZ versions.
The error only occurs after inserting the subroutine.
THE TEST PROGRAM
DO
PAUSE 500
PRINT "HELLO WORLD"
TEST()
LOOP
SUB TEST ()
FOR i = 1 TO 30
PAUSE 50
NEXT i
END SUB
RESULT
RUN
HELLO WORLD
HELLO WORLD
'CONTOL-C pressed = program stop
> continue
[5] Loop
Error: LOOP without a matching DO
Greetings from TIROL-AUSTRIA
Posted: 06:51pm 02 Oct 2018
This is a known issue. The problem occurs when the crtl-c happens when execution is in the subroutine. Geoff is aware.
Posted: 09:29am 03 Oct 2018
Yes, unfortunately as MMBasic has become more sophisticated (subroutines, CFunctions, etc), resuming after a CTRL-C has become more difficult. I have it on my list to fix but the answer might be to remove the CONTINUE command or at least restrict its use (not good).
By the way, greetings to Austria. I was there just a week ago (St Pölten and Vienna) and I loved your wines, particularly Sturm which was completely new to me.
GeoffEdited by Geoffg 2018-10-04
bigfix
Posted: 08:12pm 04 Oct 2018
Geoff, you should have tried this "Schilcher Sturm"
In my opinion it has much more flavour than the usual types
It is made of a special grape (Blauer Wildbacher) which only grows in a small region in southern Austria
For the NonAustrians:
Sturm is grapejuice which started fermenting and then gets cooled to stop the process, before becoming wine
So it has some alcohol already and a "bubbly" taste
Its a pity I did not know that you were around
I live close to Vienna and would have loved to show you the area
cheers
Guenter
