Local Time 12:42 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : lixie display
isochronic
Posted: 09:48am 23 Sep 2018
These don't look bad...they are a nixie alternative of sorts,
maybe lots of options
lixie
Posted: 12:34pm 23 Sep 2018
i remember seeing a cool predecessor to this, described as a 'rune clock' years ago:
http://hackedgadgets.com/2006/03/19/scratchitti-edge-lit-rune-clock/
i always felt the shortcoming - shared with nixie tubes - is that some digits are sitting at the back of the stack and so not as clearly visible.
here's an interesting question: what is the minimum number of overlaid patterns required to represent the decimal digits "0" to "9"? the number should be no more thn 7, as we already have 7-segment displays. but could one get away with less?
a theoretical lower-limit may be 4, as that would be the minimum required to represent 10 different states in binary.
btw: i don't know the answer. but it is an interesting puzzle!
rob :-)
Posted: 06:21pm 23 Sep 2018
when I was anaprentipede at EMI (early 80s) I remember we had a Wayne Kerr (phnarr phnarr) precision bridge that used these. I never really got into how they actually worked... thanks
Posted: 04:43am 25 Sep 2018
Should be able to do it in 4 layers.
But the layers will have to be split horizontal and vertical with a light barrier in between.
This could be done by gluing aluminum foil in between.
JackRabbit
Posted: 11:17pm 25 Sep 2018
  CaptainBoing said   when I was anaprentipede at EMI (early 80s) I remember we had a Wayne Kerr (phnarr phnarr) precision bridge that used these. I never really got into how they actually worked... thanks
The ones I recall had dotted line rather than continuous engraving, like these KGM's.
My favorite of the old numeric display technologies that I recall from my early days in the industry has to be the Dekatron with the Nixie a close second.
Edited by JackRabbit 2018-09-27
Posted: 08:39am 26 Sep 2018
@JackRabbit
Yep - hat is precisely like I remember. Thanks
