Forum Index : Microcontroller and PC projects : BSS138 N-Ch MOSFET question....
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10044 |
Hi all. ![]() I have an application, where I am using some BSS138 N-channel MOSFET's as a low-side switch. PDF attached. BSS138_N-Ch_MOSFET_SOT-23.pdf They DO work fine, but I am getting some 'bleeding current' when the MOSFET is supposed to be off. Not much - about 0.152mA(152uA), but that is enough(believe it or not), to light up a super-bright LED. I would prefer to reduce this current.The circuit I have around all these MOSFET's, is 100k from gate to ground, and 1k from gate to the MM I/O pin. The SetPin command DOES NOT make use of the optional PULLUP. Can I assume that I need to drop the 100k down to about 10k or so? I tend to settle on 100k gate-to-ground resistor with P-channel MOSFET's(to hold them off), but perhaps N-channel require something different? The MOSFET's are already on the PCB and are SOT-23, along with 1206 resistor arrays(four separate resistors in one 1206 size package), so I don't really want to start hacking that unless I can get some confirmation that what I think is correct. OK all you MOSFET gurus! Your turn! Smoke makes things work. When the smoke gets out, it stops! |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6127 |
Hi Grogster, The maximum leakage current in a BSS138 is something like 5uA (at 50V Vds). If you measure 30x more you either have - Vgs > 0 (the gate voltage is not zero, simply measure with a multimeter). Since the BSS138 has a really low threshold voltage, 100mV (0.1V) can already cause this. - Vds > 50V (in other words, you have more than 50V on your LED's.). As you already guess, it could be option 1. Simple to detect, maybe more difficult to repair. Can be caused by a lot of things. Just to name some: - The Micromite output does not go to zero all the way a. there is an external pullup causing a voltage divider on the lower FET resistance b/ you are using a PWM that does not completely switch OFF (always leaves a little spike, hardly detected by a voltmeter, but the BSS138 will switch shortly). c/ the Vss of the Micromite chip, and the source of the FET doe not have the same voltage due to voltage drop across ground wires. I hope this helps Volhout PicomiteVGA PETSCII ROBOTS |
| Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1153 |
Hi Grogster, I believe it! I had the same problem with a Würth 150080GS75000 LED. I was already irritated when the LED began to glow weakly during soldering with my supposedly potential-free soldering iron... Have you tried pulling down the output pin in software yet? Frank |
Bill.b![]() Senior Member Joined: 25/06/2011 Location: AustraliaPosts: 249 |
Hi Grogs I use mosfets on a number of different projects, I find a 10K from gate to ground is required to ensure the mosfet turns completely of when the output of the processor is low. Bill In the interests of the environment, this post has been constructed entirely from recycled electrons. |
| zaphod Regular Member Joined: 03/06/2018 Location: United KingdomPosts: 93 |
Unfortunatly there is another sinister posibility and that is the device has been damaged by ESD during handling or soldering, this has happened to me before! Check your soldering iron tip is actually earthed and ensure you use full anti-static precautions when transfering from packaging to pcb and that pcb is sat on an anti-static mat that you keep touching. ESD damage often makes the devices leaky as you describe. There are no gate protection diodes on this device shown on tha data sheet so this insidious damage is highly likely. Cheers Roger 1Kwp DIY PV + Woodburner + Rainwater scavanger :) |
Hi everyone. ![]() @ Volhout - Good idea. Should have thought of that myself. Gate voltage when 'Off' is 156mV, which explains quite a bit. @ Frank N. Furter - PULLDOWN option cannot be used on outputs, only inputs. ![]() @ Bill.b - Yeah, this is what I am thinking too. I think I will change ONE of the 1206 resistor arrays, and see if that helps. If it does, I can change the others. @ zaphod - I always use a fully grounded workstation, iron, and anti-static strap while handling or working with any static sensitive components, so I think I am OK there. I also touch a few metal earthed things such as my microscope and PSU before I touch anything, to ensure I am at the same potential. I know how sensitive the gates on MOSFETS can be, so I went in armed. I think the problem is the stray 156mV on the gate when the I/O pin is supposed to be zero.EDIT: Voltage on MM pin when 'Off' is 16mV. I don't know how that translates to 156mV at the gate. I will swap one of the 100k arrays for a 10k one and report back.EDIT: Swapped one 100k for a 10k one, but exactly the same problem. Voltage on gate is now 172mV, so we have GAINED 20mV gate voltage by lowering the ground resistor to 10k. A bit mystified by this. Anyone got any more hints or suggestions? EDIT: Have elected to drop all the MOSFET's and resistors in favour of a couple of ULN2003A relay driver chips. They can handle more current anyway, and I have used these before. Not sure why I did not think to use them in the first place.... Smoke makes things work. When the smoke gets out, it stops! |
