Forum Index : Microcontroller and PC projects : Milestone: Grogster’s 6000th Post
Chopperp![]() Guru Joined: 03/01/2018 Location: AustraliaPosts: 1131 |
FYI Grogster is rapidly approaching the 6000 post milestone. Well done G. You certainly help to make the TBS a great place to visit. Brian ChopperP |
| Paul_L Guru Joined: 03/03/2016 Location: United StatesPosts: 769 |
Well ... either he's 1. very lonely over there in Kiwi land ... 2. or he's got a lot to say ... 3. or he's got a lot of questions ... 4. or he's developing a case of Tourette's Keyboard Syndrome. I vote for number 2, but I suppose we can't eliminate number 1 completely. The forum wouldn't be the same without you Graeme! Keep on, keeping on. Paul in NY |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10044 |
Well.... Thanks, ChopperP for the thoughts. This forum really is kinda my 2nd home. The things I have learnt from other members since I signed up..... @ Paul_L - 1 and 3. Being single and no kids, I can spend ALL my spare time and money, on things that I want. I don't need to fund a family. Not that I don't like kids - I do. Not that I don't like women - I most certainly do. But both can be expensive. With no disrespect to any female members we might have here..... Smoke makes things work. When the smoke gets out, it stops! |
Made it!!! (this is the 6000th post) Smoke makes things work. When the smoke gets out, it stops! |
| Gizmo Admin Group Joined: 05/06/2004 Location: AustraliaPosts: 5196 |
You know I should reset it to 0 Well done Grogster. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
| Azure Guru Joined: 09/11/2017 Location: AustraliaPosts: 446 |
No not 0... we need it to be -6000, only kidding. Great work Grogster as a newcomer I value all of the contributions you make, helping make the world of the MM a better place. |
bigmik![]() Guru Joined: 20/06/2011 Location: AustraliaPosts: 2981 |
Good One Grogs, I was keeping pace with you a few years ago.. But now you are nearly 3 times my posts.. I think the difference is I have stayed with the 28pin family and now the Mite World has, almost, moved past that with MM+ and Extreme families.. Anyway Retirement starts in 34 days so maybe some MuP-4/5/6/7/8/9 will be my new Frankenstein's Monster. I did see that you were single and no-kids .. Well there is a major reason I couldnt manage to keep up with you. . Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Only exceeded by the number of boards he designs. VK7JH MMedit |
