Local Time 17:40 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Display Controller Datasheets
Azure
Posted: 02:31am 07 Aug 2018
I have found this site which maybe handy for people wanting LCD display chipset datasheets.
They have many datasheets listed by manufacturer for various display controller chipsets just as a reference repository they put together. I think all the standard MM ones are there under the various manufacturers names: ST is Sitronix, SSD is Solomon Systech and IlI is Ilitek to name a few.
I came across it as I am trying to connect a ST7735S with 1.8" display which did not work on a MM+64 straight away. So in searching TBS I found out more about the differences in ST7735 and ST7735R which led me to search for the ST7735S.
Anyway, hope it comes in handy if you did not know about it already.
