Local Time 17:55 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Battery Powered Mite
palcal
Posted: 09:02pm 18 Jul 2018
I am currently running a mite off an 18650 lithium and using one of these
Dual USB 5V 1A 2.1A
It reads the state of the battery as a percentage, a short press on the switch turns on the back light and a long press is on/off, and just plug it into a USB power source to charge. Could also be used to charge a phone etc. For around $3 from ali express.
Paul.
disco4now
Posted: 11:59pm 18 Jul 2018
Hi Paul,
Does it still supply power to the output while its charging? I have a number of the USB power things and only 1 of them, the very first one I got will supply output while it is charging, the rest switch off the output while being charged.
Gerry
F4 H7FotSF4xGT
palcal
Posted: 12:01am 19 Jul 2018
I tried to connect to see if it would do that but the USB sockets are too close together to get both plugs in.
Paul
