Local Time 18:08 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Line Input versus Input$
panky
Posted: 07:11am 16 Jul 2018
According to the manual,
LINE INPUT [promp$,]string-variable
is targetted at reading a complete line from console or
LINE INPUT #nbr,string-variable
.. from a serial comms port opened previously opened for INPUT.
INPUT$(nbr,[#]fnbr)
is targeted at reading nbr numbers of characters also from a serial comms port previously opened for INPUT. If nbr is greater than the number of characters available, the entire buffer will be read ( or file - see below).
Both forms also work if a file is opened for INPUT.
There is one caveat!!!
If the file being read from has NO CR LF at the end, then LINE INPUT will not read the last character but INPUT$ will. See example code below.
If the file includes a CR LF at the end, then both forms of input work the same.
panky
DIM tstdata$ = "abc"
DIM junk1$,junk2$
PRINT "Test 1"
OPEN "test1.dat" FOR OUTPUT AS #1
PRINT "First, print data as it is written to file"
' write characters abc to file with no trailing CR LF
PRINT #1, tstdata$;
PRINT tstdata$;
PRINT
CLOSE #1
PRINT
OPEN "test1.dat" FOR INPUT AS #1
LINE INPUT #1, junk1$
PRINT "File input using LINE INPUT ",junk1$
CLOSE #1
junk2$ =
INPUT$(255, #1)
PRINT "File input using INPUT$ ",junk2$
CLOSE #1
END
flip
Posted: 01:30pm 16 Jul 2018
I'm not seeing that behaviour. When I tried above, I got as follows:
DOS MMBasic Ver 5.04.08
Copyright 2011-2017 Geoff Graham
Test 1
abc
File input using LINE INPUT abc
File input using INPUT$ abc
The file is 3 bytes long (No CRLF) but can't see any problems (interesting and handy that INPUT$(255) doesn't complaint even though it's a 3-byte file)
PhilEdited by flip 2018-07-17
panky
Posted: 01:40am 17 Jul 2018
Hi Phil,
You are absolutely correct - in MMBasic for DOS ver 5.04.08 it works correctly (that is, LINE INPUT picks up all characters in the file even without a trailing CR).
But, in MMBasic Plus ver 5.04.10b3, LINE INPUT skips the last character in a file if there is no trailing CR.
I think what is happening is that LINE INPUT, when used with the console as input, gets characters until it receives a CR (the Enter key was pressed), it discards this character (the CR) and terminates the LINE INPUT command with the correct characters in the variable assigned.
When used with a file as the input source, LINE INPUT gets to the end of the file and as before, discards the last character because it thinks it is the terminating character as the CR was above. The terminating trigger was in fact an internal flag indicating end-of-file so the last character has been incorrectly discarded.
One for Geoff and/or Peter to comment on I think, but I am pretty sure it is not intended to operate this way (ie. a bug!).
Doug.
